Ford Edge dash lights up-tach & speedo dead
mrpc9886
Vehicle: Ford Edge, 3.5l, 285hp, 2014
Post by mrpc9886 » Sat Oct 12, 2019 1:20 am
Like it says, the 2014 80,000 mile Ford Edge SE starts normally, but then the warning lights and chimes come on one by one - TRAC, ABS, Charging System, TPMS and the speedo and tach die. According to FORSCAN all the modules DTC report "loss of communications"-
My question is- "where's the root cause?" PCM issue? Elsewhere? Tips on troubleshooting welcome!
here's the DTC codes logged:
===PCM DTC P160A:00-2F=== (NOTE: no programming changes made- no different sized tires- nada)
Code: P160A - Control Module Vehicle Options Reconfiguration Error
Status:
===END PCM===
===OBDII DTC ===
Successful DTC reading, no error codes found
Module: On Board Diagnostic II
===END OBDII===
===FCIM DTC ===
Module: Front Controls Interface Module
===END FCIM===
===FCDIM DTC ===
Module: Front Control/Display Interface Module
===END FCDIM===
===FLM DTC ===
Module: Front Lighting Control Module
===END FLM===
===OCS DTC U0100:00-08===
Code: U0100 - Lost Communication With ECM/PCM A
Status:
Module: Occupant Classification System Module
===END OCS===
===ABS DTC U0151:00-20===
Code: U0151 - Lost Communication With Restraints Control Module
Status:
Module: Antilock braking system
===END ABS===
===ABS DTC U0212:00-28===
Code: U0212 - Lost Communication With Steering Column Control Module
Status:
===END ABS===
===ABS DTC U0001:88-28===
Code: U0001 - High Speed CAN Communication Bus
Additional Fault Symptom:
- Bus Off
Status:
===END ABS===
===ABS DTC C0040:64-68===
Code: C0040 - Brake Pedal Switch A
- Signal Plausibility Failure
Status:
- Test not complete
===END ABS===
===ABS DTC U0100:00-28===
Status:
===END ABS===
===ABS DTC U0140:00-68===
Code: U0140 - Lost Communication With Body Control Module
Status:
- Test not complete
===END ABS===
===RCM DTC U0140:00-08===
Status:
===END RCM===
===RCM DTC B00A0:68-08===
Code: B00A0 - Occupant Classification System
- Event Information
Status:
===END RCM===
===RCM DTC U0028:08-08===
Code: U0028 - Vehicle Communication Bus A
- Bus Signal/Message Failures
Status:
===END RCM===
===ACM DTC U0256:00-08===
Code: U0256 - Lost Communication With Front Controls Interface Module A
Status:
Module: Audio Control Module
===END ACM===
===BdyCM DTC U0100:00-08===
Status:
Module: Body Control Module
===END BdyCM===
===SCCM DTC ===
Module: Steering Column Control Module
===END SCCM===
===IPC DTC P1706:62-2C===
Code: P1706 - High Vehicle Speed Observed in Park
- Signal Compare Failure
Status:
- DTC Maturing - Intermittent at Time of Request
Module: Instrument Panel Control Module
===END IPC===
===IPC DTC U0100:00-28===
Status:
===END IPC===
===IPC DTC U0121:00-28===
Code: U0121 - Lost Communication With Anti-Lock Brake System (ABS) Control Module A
Status:
===END IPC===
===IPC DTC U0140:00-2E===
Status:
===END IPC===
===IPC DTC U0424:00-2F===
Code: U0424 - Invalid Data Received From HVAC Control Module
Status:
===END IPC===
===RTM DTC ===
Module: Radio Transceiver Module
===END RTM===
===HVAC DTC U0140:00-08===
Status:
Module: Heating Ventilation Air Conditioning
===END HVAC===
===HVAC DTC U0401:82-08===
Code: U0401 - Invalid Data Received from ECM/PCM A
- Alive/Sequence Counter Incorrect/Not Updated
Status:
===END HVAC===
denbo
Vehicle: ford focus 16 zetec
Re: Ford Edge dash lights up-tach & speedo dead
Post by denbo » Sat Oct 12, 2019 8:35 am
The easiest way i can think of, is can you borrow dash from other/same vehicle. Plug it in and see. You may not be able to start vehicle, but it would prove the point. If you find its your dash, there are plenty of companies out there that do repairs.
