Focus Mk2: Error code B2089 - Puddle/Approach Lamp Fault
TimFor
Post by TimFor » Tue Aug 20, 2019 10:28 am
I have Focus 2007 Mk2 Ghia. With Forscan I get Error code B2089 - "Puddle/Approach Lamp Fault" for both driver and passenger sides.
I don't know that I have those lamps. They are not on the bottom of mirror housing.
I thought they might be integrated with indicator lamps in the side of the mirror, but it seems not.
(per https://www.fordownersclub.com/forums/t ... ent=780969)
https://www.fordownersclub.com/forums/t ... ent=621473 also says for this Error code:
"ignore - it its common on Forscan to get that code if you don't have puddle lamps simple software bug".
Is this Forscan error and can it be fixed or what?
