I have on F250 with Factory cruise control. The cruise feature stopped working. All buttons on my steering wheel work with the exception of turning the cruise control on and off. Is there a way to use forscan to see if I'm activating the cruise control on off switch in real time? Also, is there a way to see if any fault code has been set if the cruise is inoperable?
