Steering Angle Sensor
goochman
Vehicle: Ford Explorer 3.5 v6 2014
Post by goochman » Tue Jul 16, 2019 12:54 pm
Running FORscan I got the following codes which all seem to point to the Steering Angle Sensor.
Is this something to worry about and have fixed? I have an extended warranty on my 2014 Explorer Limited thats about to run out.
ABS:
Code: C1B00 - Steering Angle Sensor
Additional Fault Symptom:
- Signal Plausibility Failure
Status:
- Test not complete
Module: Antilock braking system
Freeze Frame :
-GLOBTIM: 159874725 sec - Global real time
-POWER_MODE: Running - Power Mode Status
-ABS: Inactive - ABS
-AYC: Inactive - AYC
-BTCS: Inactive - BTCS -201D
-HDC: Inactive - HDC
-RSC: Inactive - RSC
-BTC: Inactive - BTC
-VAC_BST_ST: Inactive - Active Vacuum Booster State
-BST_REL_SW: Inactive - Booster Release Switch State
-HYD_PMP_ST: Inactive - Hydraulic Pump State
-VPWR_ABS: 14.10 Volt - Module supply voltage
-VSS: 47.0 km/h - Vehicle Speed
PSCM:
Status:
Module: Power Steering Control Module
Freeze Frame :
-SWRS: 0 rev/min - Steering Wheel Rotation Speed
-SW_ANGLE: 74.10 ° - Steering Wheel Angle
BdyCM:
Code: B115E - Camera Module
- Not Configured
Status:
Module: Body Control Module
