Injectors balance or similar not found
jorometa
Vehicle: Galaxy wa6 2000 163 2010
Post by jorometa » Wed Jun 26, 2019 9:19 pm
I both:
Vehicle:
Model: Ford Galaxy\S-Max
Engine: Duratorq Turbo Diesel Common Rail Injection Stage V
Capacity: 2.0L
Year: 2010
Month: 08
Generation: 2010.5MY
Fuel: Diesel
Transmission gear: Manual
and I wanted to change some things and diagnose high fuel consumption so I both:
Adapter: STN2120 v4.1.1 (ELM327 v1.3a)
The issue is I'm unable to do any of them.
- I need to activate daytime running lights - probably that will be possible with extended license but I didn't try. I will appriciate more information
- I need to change the Speech recognition language - do not know if this is actually possible at all is it?
- I want to activate automatic electronic brake - now it is engaged manually and disengaged automatically. I want it to engage automatically when turn of the engine is this possible (modification is with keyles system)
- The last but not least is the excecive fuel consumption. I'm unable to find maybe the most important parameter:
The injection correction i.e. what is the correction made by the ECU on every injector - that may be the key if the injectors need to be replaced or not
Please help me!
Thanks in advance
Here is some additional information from FORScan
Interface:
Port: COM1, 38400 kbps
Type: Prolific
Min.delay: 6 ms ( Excellent)
Errors: None
Vehicle:
Capacity: 2.0L
Year: 2010
Month: 08
Fuel: Diesel
VIN: WF0MXXGBWMAP51906
PCM - Powertrain Control Module
Part number: AG91-12A650-XG
Strategy : AG91-14C204-BG
Hardware type: MLP-XXX
Total Distance: 173860.0 km
SASM - Steering Angle Sensor Module
Part number: 9G9N-3F818-CB (latest known: 9G9N-3F818-CD)
Strategy : AV6N-14C309-AA
ABS - Antilock braking system
Part number: AG91-2C405-AA (latest known: AG91-2C405-AB)
Strategy : AG91-14C036-AA
Calibration: AG91-14C037-AA
PBM - Park Brake Control Module
Part number: 6G91-2598-CD (latest known: 6G91-2598-CF)
Strategy : 6G91-14C168-CD
Calibration: 6G91-14C169-CF
RCM - Restraint Control Module
Part number: AM2T-14B321-AC
Strategy : AM2T-14C028-AC
Calibration: AM2T-14C098-AC
HCM - Headlamp Control Module
Part number: 6M21-13K031-AF
Strategy : 6M21-14C084-AF
PSCM - Power Steering Control Module
Part number: BG91-3K514-FB (latest known: BG91-3K514-FC)
Strategy : BG91-14C072-FB
Calibration: BG91-14C073-FB
BCMii - Body Control Module
Part number: AG9T-14A073-CE
Strategy : AG9T-14C094-AE
Calibration: AG9T-14C095-AD
RHVAC - Rear Heating Ventilation Air Conditioning
Part number: 6M2T-19980-FC
Strategy : 6M2T-14C178-AB
SRM - Speech Recognition Module
Part number: 8M5T-19C112-EP
Strategy : 8M5T-14D511-EV
Calibration: 8M5T-14D512-AA
PDM - Passengers Door Control Unit
Part number: 9G9T-14B533-FC
Strategy : 9G9T-14C108-AC
Calibration: 9G9T-14C109-AC
DDM - Drivers Door Module
Part number: 9G9T-14B533-AC
Strategy : 9G9T-14C064-AC
Calibration: 9G9T-14C065-AC
PAM - Parking Aid Module
Part number: AM2T-15K866-AB
Strategy : AM2T-14C090-AB
HVAC - Heating Ventilation Air Conditioning
Part number: AS7T-18C612-CB (latest known: AS7T-18C612-CD)
Strategy : AS7T-18D619-AB
Calibration: AS7T-18D620-AB
RFA - Remote Function Actuator
Part number: 7S7T-19G481-CC (latest known: 7S7T-19G481-CE)
Strategy : 7S7T-14C104-CC
Calibration: 7S7T-14C105-AC
ACM - Audio Control Module
Strategy : AM2T-14C044-PD
IPC - Instrument Panel Control Module
Part number: AM2T-10849-VD (latest known: AM2T-10849-VE)
Strategy : AM2T-14C026-CE
Calibration: AM2T-14C026-CE
Odometer: 173860.0 km
