Injectors Ford Fiesta 1.4 TDCI 2007
Micklebreton
Vehicle: Ford Fiesta 1.4 TDCI Diesel 68 CH 2007
Post by Micklebreton » Sun Jun 09, 2019 12:26 pm
Hi everybody,
I have a problem with my injectors on my Ford Fiesta. I changed a 1st injcteur in March (because error P1201).
I rode with for 15 days without worries then I had again the led "motor fault ". This time it was the default P1203 and P1204. So I decided to change the other 3 injectors. Since I no longer have the "engine default" led but I have the following defect: P0269-60, P0266-60. The car's rolling, but I can't get past the 30 miles per hour.
I do not know why I have this defect and how to solve it. :(
denbo
Vehicle: ford focus 16 zetec
Re: Injectors Ford Fiesta 1.4 TDCI 2007
Post by denbo » Sun Jun 09, 2019 6:42 pm
Bad fuel can do that. Empty filter and test in glass jar for seperation. If you smell test, you only get one go. It does something in the nose.
Micklebreton
Post by Micklebreton » Mon Jun 10, 2019 4:32 pm
Hello, thank you for feed back. I checked the diesel. I did not detect anything. I took the opportunity to change the filter. But, this has not changed anything, I always have the 2 errors. Should we not reset the calculator? To erase data from old injectors. :?:
denbo
Post by denbo » Mon Jun 10, 2019 5:40 pm
Where did you get those injectors? were they new or reconditioned. I have had lots of trouble in the past with reconditioned injectors. Now i only fit new. if the customer dont like it, they can go elswhere
Micklebreton
Post by Micklebreton » Wed Jun 12, 2019 7:35 pm
These injectors are repackaged. I don't know their exact sources. I still feel that the calculator flanged the engine. As if it protects the engine because I have no power and no light. Your advice would be to buy new injectors :cry:
denbo
Post by denbo » Fri Jun 14, 2019 6:45 pm
Why not start with getting the injectors tested!
