Andyfocus
Post by Andyfocus » Wed Feb 06, 2019 4:30 am
Ximirit wrote:
Mon Feb 04, 2019 11:53 am
I searched information in the forum but did not find information about my problem. Please someone explain me the procedure. Thank you.
the internet is bigger than just one web site....
which is why i said do an internet search or utube.
viking560
Vehicle: Ford F150, 2016, 3,5 ecoboost
Post by viking560 » Wed Feb 06, 2019 5:08 pm
Ximirit wrote:
Sat Feb 02, 2019 12:53 pm
Hello.
I am new to this forum and I am pleasantly surprised that you are really helping. I soon bought Ford Tranzit 2.0 tdi 2000. I had to change the pump and now I can not adapt the module. I downloaded a trial license but I get a message that incode is not accepted. Please for your help.
Thank you.
Have done it a couple of times on same car. No problems at all. Maybe you need extended licence, trial version is limited in functions.
FreddyFord2012
Vehicle: 2012 F150 XLT 3.5L Ecoboost
Post by FreddyFord2012 » Tue Feb 12, 2019 8:06 pm
I only have 1 key for my 2012 F150 XLT and am purchasing a remote start OEM kit that comes with two Keyfobs I will be installing and turning on with Forscan- those two Keyfobs have 4 buttons and the one I have only 3, so I will be programming the two with the kit as masters and tossing this one I have.
Where is everyone getting their keys cut? I've seen locksmiths, Walmart, etc - I would think it would cost next to nothing if they aren't programming it. I saw Walmart has a machine you stick your keys into - don't know if that would work on a KeyFOB that I would take to the store?
Also, are you getting the two Keyfobs cut (like in my case) before, or after programming it to the truck?
Thanks!
Narly1
Vehicle: F150 STX 3.7L 2013
Post by Narly1 » Tue Feb 12, 2019 8:44 pm
Programming keyless entry buttons on your key and programming the PATS transponder chip embedded in your key are two different proceedures.
For keys my advice is to get a "dumb" (containing no transponder) key made first. Use it to rotate the lock cylinder, and while holding your new, uncut transponder key near the lock cylinder, check it with Forscan to see if it's readable.
Do this before you get the keys cut in such case that they are duds and you need to take them back to the seller.
If they check out good then take them and get them cut. I have had good luck with my local Home Depot cutting them for free, YMMV.
Then go through the whole PATS programming procedure.
I believe you can program the fobs themselves using the method shown in your owners manual
Barny76
Vehicle: Ford Explorer
Post by Barny76 » Sun Feb 24, 2019 3:18 am
I need a HELP Please !!!, I have a ford explorer 2006 with only one master key and I wanted an additional key, I went to the dealer and bought a blank key, I tried to program this new key,but I did choose delete all the keys stored and I followed all the steps at, the end says the 2 keys was programmed successfully,but when I tried to star the truck,the engine won't crank and the anti theft light is flashing,the issue is the keys was not stored really,please I need any help how resolve this issue,thanks
Barny76
Post by Barny76 » Tue Feb 26, 2019 3:23 am
Thank you so much Forscan the issue was fixed. I send them an email with the log and they replied very fast and did suggest disable the unlimited key code, I did it and I could to program two keys with no issues. Thank you so much Forscan, I appreciate a lot your help and information
Barzerify
Vehicle: Ford Focus, TDCi 1.8/74kW, 2003
Post by Barzerify » Thu Feb 28, 2019 1:39 pm
I got a Focus MK1 2003. Last week my battery died so i replaced it. Since then both of my keys won't start the car and OBD shows B1601 for both keys.
Is it possible to reprogram both keys without any of them working atm? One of the keys got a remote, the other one is simple with a blue transponder.
Hindiantoro
Vehicle: Everest, TDCi , 2.5L, 2010
Post by Hindiantoro » Sat Mar 02, 2019 11:42 am
Hello FORScan Team,
How can I use FORScan to create key for my Ford Everest 2.5L TDCi? I can not find any menu in service with PATS programming.
Thanks a lots.
fordnick
Vehicle: Ford BA Fairmont 2003
Post by fordnick » Mon Mar 04, 2019 5:28 am
Successfully added 2 new keys to my 2003 Ford BA today after only receiving 1 with secondhand car. Forscan walked me through it and it worked perfectly. Hardest bit was waiting 12 mins for Ford security process. Thanks Forscan team.
FYI after reading posts I had some concerns over ebay items. I will say that I think you should get decent keys (without chip) from a (decent) locksmith. Mine were Silca.
The wedge chip for my car 4D60 has 145-00 on it (the second line of numbers is just a batch number I believe). I had some concerns because a useless Mr Minute man (who couldn't even cut a key right) said mine was a 4D62.
I got a Vgate iCar2 bluetooth OBD module and it seems to read/write all OBD functions perfectly.
f-wolf
Vehicle: *** Ford ***
Post by f-wolf » Mon Mar 04, 2019 5:50 am
Re, Successfully added 2 new keys to my 2003 Ford BF
You mean BA !! ?
Well done !
