Hello !
i noticed it
S-Max 2.0 TDCi 110kw
Ignition key the ON position, engine not running and MAF sensor shows 2,11 g/s
this is normal ?
MAF sensor diagnose
- Vehicle: FORD S-MAX 2,0TDCi PowerShift
MAF sensor diagnose
- Maf sensor
- MAF sensor.PNG (414.66 KiB) Viewed 179 times
Re: MAF sensor diagnose
That is not normal. It should read 0 when the engine is not running.
I don't know the exact figures for your engine, but at tick over I would expect it to be somewhere around 6 or 7 and be steady, and rise to high double figures under extreme load.
Hopefully someone with the same engine as you can confirm the normal expected values.
These are the readings from a MAZDA 3 2L Petrol 2010
Ignition on Engine NOT running
And
Engine running ... Idling at about 750RPM
Try to clean your MAF Sensor with Sensor Cleaner first ...
And
Thanks !
when the engine running 800rpm and maf 12g/s
i can't find the Forscan MAF sensor volt PID-s only MAF g/s and MAF hz
car mileage is 25000km
I installed a new maf sensor today, the result is same 2.11 g/s
- new maf.PNG (395.06 KiB) Viewed 60 times
start-stop systemDonny wrote: ↑Sun Feb 10, 2019 9:30 pmThat is not normal. It should read 0 when the engine is not running.
