Programming ..
benrsturbo92
Vehicle: Escort RS turbo
Programming ..
Post by benrsturbo92 » Sun Jun 23, 2019 11:50 am
I have a project on the go at the moment and would like some advice.
Im fitting a 1.8TDci engine into a older car (they are abit smoother than a tddi :lol: ) the fitting isn't a issue.
I have got the engine, wiring loom(full car), ecu, clocks, ignition switch and transponder but the only issue here is i do not have the key is there any help i could gather to help me program a key without having the original one.
When plugged into FORScan i can not see anything under programming
Could a ecu reset / reflash and relearn be my only way?
EDIT : ecu/engine/loom is from 2006 ford focus 1.8tdci 115)
mtnbiker995
Vehicle: 2011 6.7 F250, 2016 Explorer EcoBoost
Re: Programming ..
Post by mtnbiker995 » Sun Jun 23, 2019 12:56 pm
Do you have the extended license? I've only had FORScan for a few hours, but I'm pretty sure programming a key is one of the functions you would need to purchase an extended license for.
benrsturbo92
Re: Programming ..
Post by benrsturbo92 » Sun Jun 23, 2019 1:03 pm
No, but it should still show as a function i believe.
AS soon as i know it will do what i need it to do i will have no problems getting a life time license.
mtnbiker995
Re: Programming ..
Post by mtnbiker995 » Sun Jun 23, 2019 3:54 pm
I can try it out tonight when I get home and let you know.
benrsturbo92
Re: Programming ..
Post by benrsturbo92 » Sun Jun 23, 2019 7:45 pm
Thanks if you could , retro fitting the engine etc into a older car is easy part but because the items where out of a scrap yard someone else had already gotten the original key so i need to someone get a new key programmed to the ecu.
Andyfocus
Re: Programming ..
Post by Andyfocus » Sun Jun 23, 2019 8:28 pm
you dont need the buy a licence to try it out , you can get a trial licence for 2 or 3 months to see if it works then buy a lifetime licence if you still need to .
Lee25
Vehicle: Focus Zetec, 1.6
Re: Programming ..
Post by Lee25 » Mon Jun 24, 2019 9:16 am
You don’t need a new key just programme your old key into the new ecu, also the part you say is the transponder is just a receiver for the key and they’re all the same so don’t need to change it
benrsturbo92
Re: Programming ..
Post by benrsturbo92 » Mon Jun 24, 2019 4:12 pm
I haven't got a key for it , i have all the parts i have collected from the scrap yard i have receipts to prove where it was from from, im not trying to steal cars or any funny business.
Lee25
Re: Programming ..
Post by Lee25 » Mon Jun 24, 2019 5:20 pm
What are you planning on putting it in?
benrsturbo92
Re: Programming ..
Post by benrsturbo92 » Mon Jun 24, 2019 6:19 pm
an older mondeo but first i want to get it running on the floor then will find out about mounting everything.
its probably (well almost definatley) not worth doing BUT the car has sentimental value has it was bought brand new.
