Transmission shift points after larger tires
Robb8
Vehicle: F150 lariat , 5.0L V8 , 2018
Post by Robb8 » Fri May 31, 2019 9:02 pm
Hey guys I’m getting 34.3 cooper STT pros on 18 fuel vapours , my question is about transmission shift points as I’m being told they will have to be calibrated afterwards current tires are about 31’ on 20’ ... I’ve read a few posts saying that calibrating your speedo helps with this but others saying it’s independant from the speedo but does not require any calibration any thoughts ?
2018 f150 lariat 5.0 , 3.31 gear ratio
tha5150
Vehicle: f150 xlt, 2.7,, 2015
Re: Transmission shift points after larger tires
Post by tha5150 » Wed Jun 05, 2019 12:54 am
Interested as well. Got 33 Toyo’s And when I changed to recommended settings, the mph was 3 over. Factory settings were right..?? Makes no sense. Then I started thinking about the shift points and been scratching the noggin.
theandies
Vehicle: 2015 Ford Explorer, 2016 Ford Fusion
Post by theandies » Sun Jun 09, 2019 1:31 am
Transmission adaptive learning will reset if you disconnect the battery. That's should do it.
mtnbiker995
Vehicle: 2011 6.7 F250, 2016 Explorer EcoBoost
Post by mtnbiker995 » Sun Jun 23, 2019 1:03 pm
Is there not a way to reset the adaptive learning tables with FORScan?
mtnbiker995
Post by mtnbiker995 » Mon Jun 24, 2019 1:06 am
Back home and can mess around with it. If you are interested in resetting the adaptive learning tables, you can do so with FORScan. Under service procedures, TCM, clear transmission adaptive tables.
Randy2015
Vehicle: 2015 Ford F250 6.2 flex
Post by Randy2015 » Tue Jun 25, 2019 3:37 pm
My 15 F250 came with 17's I am guessing.... I updated to a 265/75/20 (not 100% on the 75 part cannot remember) anyways my speedo still isn't right however trans shifts fine snap a GPS ap and double check speedo is my advice... the TCM will handle rest
