FORScan issues
409f150
Vehicle: 2018 f150 5.0
FORScan issues
Post by 409f150 » Sat May 11, 2019 11:10 pm
I have a 2018 F150 and when attempting to change a few things I lose my drive modes. I started off with bambi mode when you cycle the key off/on it displays a message saying drive modes not available. Can go in and set back to stock and drive modes come back. No matter what i change the same thing happens, but as soon as you go back to the factory setting everything works fine. Anyone have an idea what the issue could be?
denbo
Vehicle: ford focus 16 zetec
Re: FORScan issues
Post by denbo » Mon May 13, 2019 6:56 pm
Not sure forscan can do 2018 models. Do a search and i,m sure you will find out for sure.
409f150
Re: FORScan issues
Post by 409f150 » Tue May 14, 2019 5:29 am
i have a spread sheet for the 15-19 f150s
https://docs.google.com/spreadsheets/d/ ... =815852466
steeltanker109
Vehicle: ford f150 supercrew 5.0 2018
Re: FORScan issues
Post by steeltanker109 » Wed Jul 17, 2019 2:26 am
This happend to me today I discovered if you reset your values it will come back it scared the shit out of me turning off start stop affects other things that I didn't like
Don Ridley
Vehicle: 2016 Transit Connect
Re: FORScan issues
Post by Don Ridley » Wed Jul 17, 2019 3:23 pm
Some changes create temporary side effects. Sometimes you need to drive the vehicle for a while to trigger or reset the item that is causing the strange behavior. Nobody knows exactly what is going on and the symptoms change by vehicle and item changed.
My vehicle always thinks the right rear door is unlocked after any Forscan change. Locking the doors using the button inside the vehicle fixes it.
TJ2019F150SXT
Vehicle: Ford F150, 3.5L Ecoboost, 2019
Re: FORScan issues
Post by TJ2019F150SXT » Sat Aug 31, 2019 2:35 pm
Thanks! Ditto for me ... so I changed it back to original configuration and error is gone
