Ba Falcon parameter reset. Can it be done?
sd6
Vehicle: 2003 ba xr6 falcon
Post by sd6 » Fri Apr 26, 2019 12:57 am
I'm in the process of doing an engine swap on a 2003 ba xr6 falcon. I am installing a turbo engine along with the turbo pcm so I will need to do a parameter reset to link up the new pcm along with specifying things like diff ratio equipped, traction control or not etc.
Can forscan do this function on the ba falcons?
Xr6turbo
Vehicle: Ford xr6 turbo
Re: Ba Falcon parameter reset. Can it be done?
Post by Xr6turbo » Fri Jun 19, 2020 6:27 am
Have you had any luck i currently am doing the same my BA xr6T caught fire inside so I'll be swapping tansmisson ecu/pcm diff etc into a NA BA falcon and am looking around to find if this tool will help cheers
oldtinfords
Vehicle: BFII XR8 boss 260 5.4l 2006....BFII XR6T 2007....
Post by oldtinfords » Tue Jul 07, 2020 12:53 am
FORScan is a great tool & can do the parameter reset & program modules but can't adjust the diff ratio in the PCM. HPTuners, PCMtec or the like can change the diff ratio & specify ABS/TCS etc.....IDS is another but I don't like going to Ford to do anything if I can get away with it :lol:
AFR
Vehicle: Falcon XR6T Sprint I6T 4000cc 370Kw
Post by AFR » Sat Aug 15, 2020 2:05 am
as long as you do a complete engine and engine loom swop it will work. Turbo have additional wiring. Forscan will do what you need it to d.Its much easier than doing FG Mk1 5 to 6 speed and Mk1 to Mk2 conversion
