Couple of question about CC
ford18
Vehicle: Tourneo Courier Ecoboost 1.0 2018
Post by ford18 » Mon Apr 15, 2019 12:37 pm
First, thank you for providing FORScan :)
I read many pages and got few questions, not sure where to post, I hope this is the right place.
About Central Configuration, in the How To it says
FORScan estimates quality of adapters
Can you give some information about how FORScan estimates the adapters?
There and in this tutorial we can read that programming via the Central Configuration is easy, but not always safe so it is recommended to use the Advanced method and edit the hexa values.
Would it be possible to add an option in CC in order to show the addresses and values that will/should be updated? That way we could either make the change manually, or at least, go and check those specific addresses to check that the changes were correctly applied.
