mustang 2018 big LCD
Posted: Thu Mar 21, 2019 6:59 am
by afreen
HI
PLEASE SOME BODY CAN HELP TO CHANGE DASH FROM MIL TO KM
Re: mustang 2018 big LCD
Posted: Tue Mar 26, 2019 6:21 am
by 43p6cl43
You can use UCDS to program the IPC but you need the calibration files for the KM Version. It takes about 1 1/2 hours to do the update. You have to leave your car running and then it shuts down automatically after 1 hr just let it run and finish. I would use a battery back up as well.
Posted: Tue Mar 26, 2019 8:59 pm
by gg1234635
Use forscan and make sure you have the correct country code on the IPC and that you have the correct setting selected on the settings on forscan itself to the correct one.
Those together should solve your problem
