mustang 2018 big LCD
afreen
Vehicle: musting 5.0 2017
Post by afreen » Thu Mar 21, 2019 6:59 am
HI
PLEASE SOME BODY CAN HELP TO CHANGE DASH FROM MIL TO KM
43p6cl43
Vehicle: 2016 Ford Mustang
Re: mustang 2018 big LCD
Post by 43p6cl43 » Tue Mar 26, 2019 6:21 am
You can use UCDS to program the IPC but you need the calibration files for the KM Version. It takes about 1 1/2 hours to do the update. You have to leave your car running and then it shuts down automatically after 1 hr just let it run and finish. I would use a battery back up as well.
gg1234635
Post by gg1234635 » Tue Mar 26, 2019 8:59 pm
Use forscan and make sure you have the correct country code on the IPC and that you have the correct setting selected on the settings on forscan itself to the correct one.
Those together should solve your problem
