FORSCAN Question on 2011 Lincoln MKS
Quasar3210
Vehicle: Lincoln MKS, 3.7 liter V6, 2011
Post by Quasar3210 » Mon Mar 18, 2019 11:11 pm
Hi all, Just got a bluetooth obd reader and got Forscan. I have a 2011 Lincoln MKS with the 3.7 V6 and AWD. Not having a whole lotta luck finding any very specific info for memy car. Is it ok to just use the Taurus info I find throughout the forum. I am mostly interested in setting for fogs on with high beams, adjusting tire size and possibly deactivating front park sensors and maybe seatbelt dingers. I am also trying to chase down a short to ground in my interior lamps. Hopefully there might be tests to help me find the short. Any advice for a Forscan Newb? Looking forward to being around and eventually helping others.
Martyx11
Vehicle: 2011 Ford Taurus
Re: FORSCAN Question on 2011 Lincoln MKS
Post by Martyx11 » Wed Mar 20, 2019 1:57 pm
Hi I have a 2011 Taurus and I'm having problems getting into the BCM that module just don't show up in Forscan. When you load your modules in forscan can you see the module BCM? Have a look at my post and you can see what modules I get to show up. viewtopic.php?f=5&t=8963
denbo
Vehicle: ford focus 16 zetec
Post by denbo » Wed Mar 20, 2019 8:09 pm
The bluetooth ones do give problems, if you read other postings.
Automate
Post by Automate » Wed Mar 20, 2019 11:08 pm
@Martyx11 Did you not see Andyfocus post?
QuikFord
Vehicle: 2005 F150 STX 4.6 2013 MKS 3.7 NA 2WD
Post by QuikFord » Thu Mar 21, 2019 7:48 pm
Quasar3210 What are you looking to do with you Lincoln? The MKS is has most of the options you could add to a Taurus.
2013 Lincoln MKS 3.7 TiVCT 2WD
2005 F150 STX 4x4 4.6L
