Forscan in Mac OS X
mkillewald
Vehicle: 2018 F150 XLT 2.7l Ecoboost
Re: Forscan in Mac OS X
Post by mkillewald » Wed Aug 29, 2018 6:38 pm
I successfully have Forscan running on 10.13.6 (2018 MBP) using VirtualBox with Windows 10 Home unactivated and a USB ELMconfig device with MS/HS switch. It took a bit of playing around to get Windows to recognize the USB device. Here are the steps I took (best I can remember) that worked:
1. Install Mac OS X FTDI driver 2.4.2 (http://www.ftdichip.com/Drivers/VCP.htm)
2. Install VirtualBox Extension Pack in OS X (http://www.ftdichip.com/Drivers/VCP.htm)
3. Plug ELM device into USB port (with USB-C dongle), but don't attach to vehicle
4. Enable USB 3.0 and the FTDI FT232R USB UART [0600] device in VirtualBox port settings for the Windows 10 VM
5. Install Windows FTDI driver using setup.exe package (http://www.ftdichip.com/Drivers/VCP.htm)
6. Restart Windows 10 VM (may not be necessary, but why not)
7. Attach ELM device to vehicle
8. Run Forscan on the VM
9. Cross fingers and hope it all works!
nikstik
Vehicle: 2010 ford transit
Post by nikstik » Thu Aug 29, 2019 1:19 am
Hi guys im new here and have a macbook pro 2010 running high sierra 10.13 and a elm327 usb plug in obd2 unit, have had a read of a few of the posts and not sure which is the easiest way to get this working? Any ideas as i've never been a pc guy ;)
nikstik
Post by nikstik » Thu Aug 29, 2019 1:21 am
tried this but got stuck at number 4 :(
Hewzey
Vehicle: Ford transit 2.2tdci 115 fwd trend 2009
Post by Hewzey » Sat Dec 28, 2019 4:02 pm
oldish thread, I know, but this worked perfectly for me. don't forget that to implement step 4 you must have powered off windows in VirtualBox and not just saved it. In a saved state the option to enable the usb 3.0 and the FTDI device won't be available (greyed out) and the elm won't connect until it has been enabled. Hope this helps...
