12.5mpg help transit help
rikki661
Vehicle: ford transit350 2.2 2015
Post by rikki661 » Wed Jan 23, 2019 10:37 pm
Hi can someone help me find out why I am only getting 12.5 mpg, the van runs fine no smoke it's responsive sounds ok,can some one help me read the live data and what live data I need to read to see what's going on, all looks OK to me, it's a ford transit 350 lwb 2015 mk8 engine fs2 thanks so much to anyone who can help
Andyfocus
Re: 12.5mpg help transit help
Post by Andyfocus » Wed Jan 23, 2019 11:29 pm
could be worth looking for a fuel leak or someone stealing your fuel lol.
rikki661
Post by rikki661 » Thu Jan 24, 2019 5:26 pm
Haha thank for the reply but no leaks, all wheels free wheeling clean air filter, no codes coming up
Andyfocus
Post by Andyfocus » Thu Jan 24, 2019 6:39 pm
hmm ok may be worth doing a ecm reset then to make it relearn injector levels , you sure you didnt buy a pair of lead boots lately ?
rikki661
Post by rikki661 » Thu Jan 24, 2019 7:33 pm
Haha left the lead boots on the misses at the local lake when we went swimming,can you explain how I do the Ecm reset and injector relearn so I don't make a mess of things and do you think I can do it without killing it altogether lol
rikki661
Post by rikki661 » Thu Jan 24, 2019 7:35 pm
Also how long does it take to do, so I give myself enough time to complete it thanks for the help
Andyfocus
Post by Andyfocus » Fri Jan 25, 2019 3:13 pm
once forscan is connected goto the pcm /ecm reset relearn , then go for a drive down a motorway and just drive normally then let the car slow by its self not letting revs drop below 1500 or above think it was like 3500 ish then accelorate back up again then let it slow down using engine braking again ( believe 3rd gear was the one to do it in , but any gear that your not changing gear or having to do anything apart from accelorating / decellorating ) .), do that 4 or 5 times think someone did it for 25 minutes but should take about 15 to 20 minutes , then go home and read the values again.
bewarned sometimes when resetting it you have to rev the engine to keep it running for 10 to 20 secounds after reset while it does an initial set up , best to do it on a warm engine seems to help a little and gets a better injector setting as the engines upto normal running temp already .
rikki661
Post by rikki661 » Fri Jan 25, 2019 9:55 pm
Here’s my options which one do you mean sorry for not getting it but I don’t want to mess it up, today I very nearly set it back to factory but saw it before I did it thank god I don’t want to make it worse lol
rikki661
Post by rikki661 » Fri Jan 25, 2019 9:59 pm
Also did some reading blocks are these meant to have readings in them is than what we are resetting
Chug
Vehicle: Ford Transit
Post by Chug » Sat Jan 26, 2019 3:51 pm
Not sure about the injector learns, but it looks like second in the options list, and for live data you select what you want to see in the setup tab at bottom of screen and then click the arrow at the bottom of the screen in your second pic to read the live data of your selected items.
