APIM Focus MK4
hwk
Vehicle: focus mk4 1.5 ecoboost 2018
Re: APIM Focus MK4
Post by hwk » Sun Apr 28, 2019 1:05 pm
@gg1234635 I've just sent an email to FORScan guys with all the logs I could find. Let's see :)
hwk
Re: APIM Focus MK4
Post by hwk » Tue Apr 30, 2019 8:03 am
The owner of "My-Ford-Focus" youtube channel posted a video https://youtu.be/FYpBlAQgtvY?t=112
where he mentioned the issue with APIM module not being recognised, and suggests disconnecting the car's battery for a while as a workaround.
aarueira
Vehicle: Ecosport 2019 SE 1.5 AT
Re: APIM Focus MK4
Post by aarueira » Tue Jun 11, 2019 7:42 pm
Have you tried to disconnect the battery? Does it work?
danielhartman
Vehicle: Ford Transit Custom 2.0 2018
Re: APIM Focus MK4
Post by danielhartman » Sun Sep 08, 2019 1:57 pm
Hi!
I'm a new owner of a Ford focus st-line mk4 of 2018.
My forscan isn't able to see the APIM module.
Is there a solution available right now?
Daniel
davetcollection
Vehicle: Focus '17 ST-Line 1.0 Auto, Focus 4 1.5D Titanium
Re: APIM Focus MK4
Post by davetcollection » Fri Sep 27, 2019 6:57 am
Any news on APIM yet?
focusstlineclaudio
Vehicle: FORD focus mk4 st line 1000cc 125cv 2018
Re: APIM Focus MK4
Post by focusstlineclaudio » Sat Sep 28, 2019 11:38 am
yo dese que compre el coche hace 1 año , usando el forscan no me detectaba el APIM, solo lo hacia si desconectaba el borne negativo de la bateria, pero mientras no encendiera el coche se veia, pero cuando lo ponia en marcha desaparecia en forscan.
Anoche lo he conectado y mientras leia los modulos he encendido el coche y a aparecido el modulo APIM.. no se si es esto por esta accion o porque en alguna actualizacion de forscan o del coche, lo deja hacer.
Focus-MK4
Re: APIM Focus MK4
Post by Focus-MK4 » Tue Oct 01, 2019 10:22 am
Hi all,
there are two possibilities:
- Disconnect Battery and re-connect again (please keep attention to not short-circuit something)
- Try module reset in FORScan (even when not visible)
Keep in mind not to load the profile again when establishing a connection. Please create a new Profile (so FORScan will initiate all modules again)
For further information subscribe to my channel - if I have something new I will keep my YouTube Channel updated :)
semiho
Vehicle: Focus Mk4 St-Line Ecoblue A/T
Re: APIM Focus MK4
Post by semiho » Sat Oct 12, 2019 10:18 pm
I should remind that some of the Focus Mk4s are not equipped with SYNC 3.
Since 2018 MY, SYNC and SYNC 3 are different things. SYNC is a simplified version of SYNC 3. Bluetooth and connectivity processes of SYNC is done by ACM, instead of APIM.
Like this;
20190204_230653 (1).jpg (283.08 KiB) Viewed 780 times
Iker Anduiza
Vehicle: ford focus mk4
Re: APIM Focus MK4
Post by Iker Anduiza » Fri Oct 18, 2019 12:49 am
Buenas,
Alguien me podria facilitar la hoja de calculo del focus mk4?
Muchas gracias.
Focus-MK4
Re: APIM Focus MK4
Post by Focus-MK4 » Fri Oct 18, 2019 11:34 am
There is no Excel-Table for the MK4 which can be shared
