APIM Focus MK4
mschumiv
Vehicle: Ford Focus MK4 1.5L 88kw diesel 2019
Re: APIM Focus MK4
Post by mschumiv » Sat Apr 13, 2019 9:44 pm
gg1234635 wrote:
Sat Apr 13, 2019 9:34 pm
Make sure your battery is fully charged or it could cause this affect
You mean the "Service procedure has been interrupted" error?
The car is almost new and i tried the procedure engine running.
gg1234635
Re: APIM Focus MK4
Post by gg1234635 » Sat Apr 13, 2019 9:49 pm
Yea but it takes the reading from the battery so it might be worth taking the car out for a run first and make sure the battery level is higher. Some changes you can not make when the engine is running also
To check this go to Read PID Date and select the battery voltage from it to monitor.
I have found myself that if it goes below a figure (11.8) you will get a warning sometimes but go to low and it will just time out with the same error that you have had.
mschumiv
Re: APIM Focus MK4
Post by mschumiv » Sat Apr 13, 2019 9:53 pm
I'll try that, see what happens.
Re: APIM Focus MK4
Post by fordsmax471 » Sun Apr 14, 2019 4:00 am
try it
sync3 hidden menu when you hold '''Eject & Seek -->> ''
FORScan v2.4.0/Els27 v4/Elitebook 840 G6/Win10 Pro
mschumiv
Re: APIM Focus MK4
Post by mschumiv » Sun Apr 14, 2019 7:20 am
try it
I don't have sync 3 ... it's a weird reduced version
20190204_230653 (1).jpg (283.08 KiB) Viewed 1946 times
And i don't have an eject button, on mk4 no more cd's.
mschumiv
Re: APIM Focus MK4
Post by mschumiv » Sun Apr 14, 2019 7:23 am
Ford update site says my car is not equipped with sync, therefor no APIM module present.
davetcollection
Vehicle: Focus '17 ST-Line 1.0 Auto, Focus 4 1.5D Titanium
Re: APIM Focus MK4
Post by davetcollection » Thu Apr 25, 2019 2:05 pm
No APIM on my Focus 4 either, ELM modded, shows up OK on wife's 2017 MK3.5 and daughter's MK8 Fiesta.
Weird one that.
I was hoping to put soft heated seat switches on sync 3 screen as I have done on Fiesta MK8 :(
funkybro7
Vehicle: Focus ecoboost 1.0 125pk 2019
Re: APIM Focus MK4
Post by funkybro7 » Sun Apr 28, 2019 11:28 am
Same strange thing, I have a 2019 Focus MK4 ST-line with the newest Sync system. Using FORScan I can find all modules but not the APIM. I'm sure my car has a APIM module :roll:
Can this be related to the Sync firmware version (using the newest) or is the latest beta of FORScan not yet compatible with my car?
hwk
Vehicle: focus mk4 1.5 ecoboost 2018
Re: APIM Focus MK4
Post by hwk » Sun Apr 28, 2019 11:54 am
mschumiv wrote:
Sat Apr 13, 2019 9:26 pm
And a Forscan related error: everytime i try to modify the BdyCM module config i get an error: Service procedure has been interrupted; everything else works.
Same "Service procedure has been interrupted" error, but on PCM module here, Focus MY19, production 2018-09, also APIM module not found. Would sending my log file to ForSCAN devs help anything, or are they aware of the issue already?
gg1234635
Re: APIM Focus MK4
Post by gg1234635 » Sun Apr 28, 2019 12:15 pm
Worth looking at the release note information on the versions as it could be the case that your apim module might not be support yet. Send the info to Forscan and they can let you know
