Hi, can extend the license on my pc? thanks
my car is Ford Fiesta Mk7
Please check date at your PC, it should be in the 2-months interval you generated the license for.Lars Vandenberg wrote: I try today to install the key file for trial extendet licens, but it dosen't work.
Download the file for two times, each file got the correct Hardware ID.
Imorting to regestry or load inside of Forscan without error message.
Restry said importing sucsessful, trying to load in Fordscan said please restart Forscan...
But no changes, the about screen said Standart licens![]()
Trying to reprogramm the GEM and IC failed with error "Sorry, you need extendet licens"
First post of this thread describes how to do it.alepa79 wrote:Hi, can extend the license on my pc? thanks
If you won't read it, here is direct link to the license generation page:
http://forscan.org/forum/extlic.php
- Vehicle: Ford Mondeo, Duratec V6 2.5L, 2005
Look's like you got a magical crystal Ball..FORScan wrote: Please check date at your PC, it should be in the 2-months interval you generated the license for.
Yes, the Date got the wrong set
Thanks a lot! Now, After revise the Date, the extendet licens appears
Greetings
Please advise...
My Australian Ford Falcon has gone into Security/Anti-Theft mode after changing the battery.
Your software has confirmed this already under the 'Standard' license.
I believe i need the "Extended License" to access PATS in order to re-program/reset/fix the issue as the car will not re-learn the key after 30 minutes with the ignition in the 'ON' position.
I have downloaded the "Extended Licence Key" successfully, but cannot get FORScan to update/acknowledge the key.
Please note that my installation of FORScan under the "About" tab does NOT have the "Load Licence Key" button.
Any assistance you could provide me would be gratefully appreciated.
Finally got around to programming a new key to my mk1.5 focus, used a cheap China copy flip key from eBay with a carbon transponder, if anyone is interested http://www.ebay.co.uk/itm/400982118010? ... 26_rdc%3D1FORScan wrote:FORScan should support Focus Mk1.5, did you try it? Doesn't service tab have PATS function?Ni72ous wrote:Hi
I would like to program a new key to my Focus but supported models are quoted as "Focus Mk1 1.8 TDCi 2001-2002 model year" mine is a 2005 facelift model (mk1.5), will it be supported in a future update?
Thanks in advance
- Vehicle: Falcon au3 4.0
Hi i dont see it explained how to just purchase an extended licence ..
I had the pcm loose my key coding and immobilsed the ecu recently .. i want to be able to fix this and i know u offer a free 2 mth useage but what happens after the 2 mths is up .. what if i need to this again in 6mths time or longrr
There is no purchase possible at the moment. Maybe in the future when the software has not beta status anymore.
You can generate a new trial license at any time. This is not a one time trial.
JASmitsMr wrote:I have downloaded the "Extended Licence Key" successfully, but cannot get FORScan to update/acknowledge the key.
1. You use very outdated version that had no that button. It may also have bugs in PATS procedures that have been fixed in more new versions. So please install latest one from this site.
2. In the future, if you need a fast feedback, please contact support by email or PM (FORScan username). Forums are mainly for public discussions and may not be processed on daily basis.
- arcomp
- Vehicle: 2015 FOCUS TITANIUM 1.6 TDCI
How to get the extended license:
Note: Regular users can get the 2-months Extended license for free, following the procedure below. Beta-testers, translators and all the other people who helped us with the project R&D can get the lifelong Extended license, following the procedure below, if they are added to a special group on the forum. Users are added to these groups by request (NOT in automated mode).
I would like to be added to a special group. What should I do. I was send to you yesterday an e-mail. please contact me.
