Vehicle: *** Ford ***
Post by f-wolf » Tue Mar 10, 2020 10:26 pm
engintronics wrote:
Tue Mar 10, 2020 4:12 pm
Followed B.1 been through it all again , for some reason this laptop insists on down loading free extended Lisc as PDF File, have reinstalled Adobe Reader DC same result, clearly something is corrupted or has corrupted the FORscan download file,have run full security system check with defender
comes up all clear, any help from your vast experience appreciated
Make sure ... That the " PDF " got the extension .key ...if not ... make it .key
Next ... Follow my instructions here :
Forscan License http://forscan.org/forum/viewtopic.php? ... f=5&t=5775
This is what the File with the correct .key extension should look like:
Forscan License 1.jpg (6.74 KiB) Viewed 1131 times
This is what the File with the wrong " PDF " extension looks like:
Forscan License -2.jpg (6.93 KiB) Viewed 1131 times
This is what the File looks like with the extension changed to .txt
Forscan License -3.jpg (72.51 KiB) Viewed 1131 times
Show Files.jpg (31.93 KiB) Viewed 1119 times
Dangerf150
Vehicle: F-150,3.5 ecoboost, 2013
Post by Dangerf150 » Tue Mar 24, 2020 12:00 am
Hello new here.
Having the extended license issue. Using older laptop it has Windows 7. Don't know where to start , just keep saying I don't have extended license. Thought I got it when I registered. someone please help.
Post by f-wolf » Tue Mar 24, 2020 12:22 am
Get free Extended License
extlic.php
FORSCAN 24.3.2020.jpg (38.32 KiB) Viewed 852 times
asdarjuan
Vehicle: Ford Focus 1.8 2007
Post by asdarjuan » Tue Mar 24, 2020 3:08 am
FORScan wrote:
Fri May 15, 2015 3:00 am
You need to generate the license and download it to PC, then open the *.key file using Windows Explorere or any other file commander. Confirm adding record to the registry. New key will replace old one.
I cannot open the .key file, tried downloading freewares which opens .key files but no success. What app do I need to open it? Thanks!
Post by f-wolf » Tue Mar 24, 2020 3:19 am
Re,
lollapalooza
Post by lollapalooza » Tue Mar 24, 2020 9:04 am
Open with ForScan
beniamino.rago
Vehicle: ford focus 1.5 tdc 2017
Post by beniamino.rago » Sat Mar 28, 2020 5:08 pm
HO UNA FORD FOCUS DEL 2017 VORREI SAPERE I CODICI PER CHIUDERE LE PORTIERE PER I FENDINEBBIA E IL TEMA GRAZIE
lech sługocki
Vehicle: ford focus mk2 1,6 tdci
Post by lech sługocki » Sat Mar 28, 2020 6:54 pm
lech sługocki
Post by lech sługocki » Sat Mar 28, 2020 6:55 pm
lollapalooza
Post by lollapalooza » Sat Mar 28, 2020 7:23 pm
English...
