jamesswright
Vehicle: 2006 Ford F350 6.0L
Post by jamesswright » Tue Oct 23, 2018 12:59 am
Tazz,
Thanks. I was able to follow that. My id was different, but after modifying it, it still wouldn't load the extended license. I've tried merging it as well, it says everything was added to the registry. still no good. Not sure what to do next. I've emailed support on the website, waiting to hear back. Maybe they can do a remote access to figure this out. Thank you again for your help.
tazzbr60
Vehicle: 04 f150 xlt
Post by tazzbr60 » Tue Oct 23, 2018 1:37 am
Tazz,
Did you also make sure your key in the registry is same as it is in the license you downloaded?
jamesswright
Post by jamesswright » Tue Oct 23, 2018 10:31 pm
Tazz,
Yes I did. It still didn't work. Today I decided to try something different. When I downloaded the extended license, I changed the file name to just "License" and saved it to my desktop. I tried the merge again, and magically it worked! I wonder if the problem was that the download had the same file name as the program? I was able to shut off the tpms on my work truck with no issues.
Just wanted to let you know that it worked out and to thank you again for tutoring my pc disability.
-Jim
42loop
Vehicle: transit connect diesel 2014
Post by 42loop » Sun Nov 04, 2018 12:10 pm
hello there,
sill I cannot use the extended license key.
i am on wine under ubuntu, the time and date are set correctly, the registry entry is correct and present and the hardware id matches,
but still its running as standard license ...
any more solutions (apart from installing a real windows ?)
greets
tom
Vehicle: 2017 f150 5.0
Post by tom » Tue Nov 06, 2018 2:08 pm
just got key last night won't load by either method listed what's the trick?
child
Vehicle: Mazda 3 BM 2013
Post by child » Wed Nov 07, 2018 4:32 pm
Extended license doesn't work for me as well. The keys have been added to registry by using "load license key" button (I confirmed that using regedit), but the application still says "standard license". I run 2.3.18 beta on Gentoo Linux using Wine.
child
Post by child » Wed Nov 07, 2018 7:51 pm
It works correctly if I install Forscan on Windows 7 in VirtualBox on my desktop, but unfortunately I can't run VirtualBox on my laptop. Not sure what the problem is with Wine, because this licensing functionality seems really basic, while the complicated stuff - car connection and data reading - works perfectly.
child
Post by child » Wed Nov 07, 2018 8:04 pm
I am ashamed I did not search the forum prior to posting that. If I did I would find this: https://forscan.org/forum/viewtopic.php ... inux#p7941
I guess I'm out of luck then :(
margadon
Vehicle: lexus GS 300 222 1998
Post by margadon » Fri Nov 09, 2018 9:10 am
добрый день ! хотел приобрести бессрочную расширенную лицензию ...возникло несколько вопросов
1 для стационарного пк и для ноутбука требуется два раза по 1500 ?
2 при смене оборудования (комп ,ноут )снова покупать лицензию ?
спасибо!
lollapalooza
Post by lollapalooza » Fri Nov 09, 2018 9:16 am
Maybe you did not notice but... this is an english speaking section :lol:
