fred08155
Post by fred08155 » Sat Apr 08, 2017 10:29 pm
grantdaly wrote:Is this possible or permisible?
Possible. But different computer = different Hardware ID. So you need to generate a license for each computer you use.
mhyll
Vehicle: Focus MK2.5, 1.6 TDCi, 80kW, 2010
Post by mhyll » Sat Apr 22, 2017 9:42 am
What donation, or payment is needed to have lifetime extedn licenses, so I do not need to regenerate after 3 months?
jokke1805
Vehicle: Ford Mondeo Mk3 ST TDCI
Post by jokke1805 » Sat Apr 22, 2017 12:46 pm
Hod do i get Extended licenses?
My forscan wirtes PATS extended licence needed etc.
i`ve changes instrumet cluster in a Focus 2008 and now the car wount start. like it`s the keys it dosen`t know in the pats.
best regards
Jes Juncher
lollapalooza
Post by lollapalooza » Mon Apr 24, 2017 6:07 am
mhyll wrote:What donation, or payment is needed to have lifetime extedn licenses, so I do not need to regenerate after 3 months?
jokke1805 wrote:Hod do i get Extended licenses?
The answer is the same for both of you: read this thread from the beginning.
KENSHIP
Vehicle: Ford F150 3.5L 2017
Post by KENSHIP » Mon May 01, 2017 1:24 pm
I am unable to get the program to effectively load the key for the trial program. I have followed the directions, using the laptop that will be used with Forscan. The key appears to download through the browser, and I am able to find it with Forscan and "load" it. Forscan gives the message "...will restart" with the new key, and does. However, when it restarts, it is always the standard license. I have tried doubleclicking on the file itself, and that appears for a moment to work as well. Still, the program restarts in standard mode. Have tried restrarting the laptop and restarting the ignition and restarting Forscan multiple times. Still all I get is "standard mode".
Any help you can provide will be appreciated.
sethjamto
Vehicle: 2016 Ford F150 3.5 Ecoboost
Post by sethjamto » Mon May 01, 2017 10:59 pm
KENSHIP wrote:I am unable to get the program to effectively load the key for the trial program. I have followed the directions, using the laptop that will be used with Forscan. The key appears to download through the browser, and I am able to find it with Forscan and "load" it. Forscan gives the message "...will restart" with the new key, and does. However, when it restarts, it is always the standard license. I have tried doubleclicking on the file itself, and that appears for a moment to work as well. Still, the program restarts in standard mode. Have tried restrarting the laptop and restarting the ignition and restarting Forscan multiple times. Still all I get is "standard mode".
I just downloaded the extended license today too and am having the same problem. No matter how many times I've done it by the instructions, when it restarts it still says standard.
Any ideas?
2016 F150 3.5 Ecoboost Lariat FX4
wilit
Vehicle: F150 - 2.7EB - 4x4 - 2017
Post by wilit » Tue May 02, 2017 2:48 am
Any ideas?
Same issue here too. I tried generating a new license to see if that was the issue, but it does the same thing. Restarts in standard mode.
EDIT: Found this thread viewtopic.php?f=5&t=3420&p=14314&hilit=trailer#p14314
I ended up fixing the date and time on the laptop and it worked. Now loaded in extended mode and shows my name.
sethjamto
Post by sethjamto » Tue May 02, 2017 11:13 am
How did you fix the date/time? My date/time show as correct and set to update automatically.
If it makes a difference, I'm on a MacBook Pro and running Forscan on Windows Parallels.
wilit
Post by wilit » Wed May 03, 2017 2:51 am
sethjamto wrote:How did you fix the date/time? My date/time show as correct and set to update automatically.
The date and time on my extremely old Dell D600 was off. Was showing January of 2005. I corrected it and re-opened the program to see that the registry key worked.
sethjamto
Post by sethjamto » Wed May 03, 2017 8:25 pm
I finally figured out why my extended license wouldn't work. Maybe this will help someone else in the future.
I'm on a MacBook Pro and running Parallels with Windows 8 Pro so that I can run Forscan (and some other stuff needed at work that only run on the dreaded Windows platform...).
I originally downloaded the extended license while running on the Mac (not Parallels), then imported the file to the desktop of Parallels. I then opened Forscan and tried importing the file. It acted like it worked, but after Forscan restarted, I was still stuck at the Standard License. I tried probably 20 different times with no luck. The Mods tried emulating what I was doing and theirs worked perfectly, so I continued playing with it in different manners.
I finally decided to delete the extended license download file and start from scratch again. This time, I downloaded the file from Forscan.org while using Windows Explorer on Parallels instead of on Firefox while on the Mac OS. The new download instantly worked!
Hopefully anyone else on Parallels either does it right the first time, or learns from my mistake!
Now it's time to tweak some things on my 2016 F150 Lariat!
