holbrook1
Vehicle: 2000 lincoln towncar 4.6
Post by holbrook1 » Sat Mar 11, 2017 3:15 pm
how do you do it? BA533C94-5B38 is my standard license number
lollapalooza
Post by lollapalooza » Sat Mar 11, 2017 11:16 pm
holbrook1 wrote:how do you get an extended license? BA533C94-5B38 is my standard license.
By looking at the post right above yours.
James199
Vehicle: Ford 7.3 2001
Post by James199 » Thu Mar 23, 2017 2:30 am
Forscan is a awesome tool and it has saved me a ton of money on my truck and the extended key let me do a few tweaks as well .. is it possable to be a tester. Thank you
Devrim
Vehicle: Mazda3, 1.5 120hp, 2015
Post by Devrim » Sat Apr 01, 2017 10:55 am
Thank you so much for this software and licence!
tom101099
Vehicle: MKZ, 2.0, 2013
Post by tom101099 » Sun Apr 02, 2017 3:38 pm
I am wondering if you could provide some help. I have the registry ID activated, however I keep getting an error code as soon as I hook up my Surface computer, "Linking Error" do I need to have the key on engine off? Also what do the settings need to be in FORScan under >settings> connections? Any Help will be greatly appreciated. Have a great day!!
FORScan wrote:In the 2.2.* branch we introduce new terms: Standard License and Extended License for Windows versions of FORScan.
Standard license is the default one distributed with FORScan. Anyone who has downloaded and installed FORScan version for Windows works under Standard license. FORScan under Standard license is fully functional, except some (few) functions that are available under Extended license only. Extended license is not provided by default and has to be obtained as described below.
The objectives of the Extended license:
1. Limit access to critical functions. For example, let's look at the PATS programming functions. If the function is available without any control, any thief who has a laptop and ELM327 can program new key just for seconds. We do not think this is something what our users want.
2. Take payment for functions that are most time/resource consuming in impementation. We are often asked about donation. We have no donation scheme, but in the future anyone who wish to help us financially has an ability to purchase the Extended license.
So in other words, if you are a FORScan user, you will have only 2 cases when you need the Extended license:
A. If you want to help to FORScan team financially (in the future, as currently we have no payment options).
B. If you need an access to a function that is available under Extended license. If it is your case, please do not try to inquire for Extended License unless you see the following message:
List of functions that require Extended license:
Note: the functions may be implemented not for all models. Please either check for your car support in Change Log on the Download page, or check for the function presence in the functions' list when FORScan is connected to the vehicle,
Service -> PATS Programming
Configuration and Programming -> Module Configuration
Configuration and Programming -> Module Configuration(AS BUILT format)
Configuration and Programming -> Central Configuration
Configuration and Programming -> Module Reset/Configuration (required to learn central configuration changes related to these modules)
All the rest functions do not require an Extended License!
How to get the extended license:
Note: Regular users can get the 2-months Extended license for free, following the procedure below. Beta-testers, translators and all the other people who helped us with the project R&D can get the lifelong Extended license, following the procedure below, if they are added to a special group on the forum. Users are added to these groups by request (NOT in automated mode).
1. Copy the Hardware Id from the About chapter of FORScan:
Important note: you need the hardware id of the equipment that directly works with your vehicle. So if you have a desktop and laptop, and you use the desktop to review the logs and the laptop is used to connect to your vehicle, you need to get the Hardware Id of you laptop!
2. Generate trial license using this link:
with the following information:
- Your First and Last name
- Contact phone
- Hardware Id obtained in the item #1
3. After license key is successfully generated, click on the Download link in the Action row of the table and download the license key to any convenient place.
4. You have 2 ways to apply the license key:
4.1. Just double-click on the file and confirm adding the registry record, then restart FORScan.
4.2. Use button Load license key in FORScan->About section, then agree to restart the application.
5. FORScan with correctly applied extended license should look like this:
matholland618
Vehicle: 2002 kenne bell mustang gt
Post by matholland618 » Thu Apr 06, 2017 2:56 pm
Sent PM regarding extended license :)
lollapalooza
Post by lollapalooza » Fri Apr 07, 2017 6:20 am
matholland618 wrote:Sent PM regarding extended license :)
You don't need to send a PM... just read the 1st post.
mink
Vehicle: Raptor, 3.5 Ecoboost, 2017
Post by mink » Sat Apr 08, 2017 12:17 pm
Do I have to have my scan tool plugged into truck to get my hardware Id ? I'm just trying to get as far as I can with setup before my new truck gets here. Thanks
Vehicle: F150 5.4 Triton 2005 Expe5.4 2003 Fusion 3.0 2010
Post by tractmec » Sat Apr 08, 2017 3:31 pm
mink wrote:Do I have to have my scan tool plugged into truck to get my hardware Id ? I'm just trying to get as far as I can with setup before my new truck gets here. Thanks
In a word no. Your Hard Ware ID is the computer or tablet that you run Forscan on and you find that in the about section of Forscan, with a link to copy it to the clipboard to start the procedure. The link is at the bottom of the L.H. column with the wheel icon!
Instructions are in first post in this thread and quoted a few posts above yours!
grantdaly
Vehicle: 2016 F150, 3.5L EcoBoost
Post by grantdaly » Sat Apr 08, 2017 5:38 pm
Hello! I would like to be able to use an extended licence on both my home and work laptops. Is this possible or permisible?
