It's easy: once expired, ask for a new one...mastercarkeys wrote:hi my extended license is about to run out how do i extend it again thanks.
- Vehicle: Ford Fiesta 1.6 TDCi 2011
I'm trying to download the Extended License and it says there's 0 bytes to download. What's going on!?FORScan wrote:You can send them using PM on this forum, or using a email address on Contact Us page on this site.Tman wrote:Hi where do I email my details to please ?
Licence due to expire 2016-08-08 but Forscan warns Extended licence required and About page has Local licence key button.
Made a new licence to download but even after load and restart the load licence button is still there.
Any clues?
Any clues?
Please, lf there's an Administrator monitoring this thread, I've loaded and reloaded the extended license key over and over again. Every time I try to download the generated key, the file shows 0 (Zero) bytes in the file. I've posted this question once already with no response. Can "Anyone" please help me so I can start using this program?
Did you try another browser? Maybe download is blocked for security reasons. You could also try to deactivate your antivirus solution while downloading.
File is really small but not zero. Mine is 258 bytes. Use right mouse click - edit to check the content of the file...
Download works fine here with Iron webbrowser.
http://www.srware.net/software_srware_iron.php
7262CE6F-60FF Please for me licenses of this id ,tks you so much
This topic should be closed. There is no need for it anymore.
It´s not the problem of FORScan if people don´t read the first post until the end and don´t even read the hints on the download page or the FAQ.
Problems with license generation (if ever again server downtime occurs) can be solved by PM or email to FORScan team.
@SPO
Read the first post of this topic, hints on downloasd page or read the FAQ!!!
You can generate the license on your own. Also you need to provide more details for the license. For license generation your full name, phone number and the hardware ID are needed.
http://forscan.org/forum/extlic.php
@SPO
- Vehicle: F150, 3.5L ecoboost, 2016
*edited.
Last edited by 2016boostedgreygoose on Fri Jul 15, 2016 6:43 am, edited 1 time in total.
This does not depend on the license. This is not the correct thread to post in.2016boostedgreygoose wrote:I generated my extended license for Windows and when I go to use the FORscan software to connect to my vehicle it starts running through checking WiFi and all the other stuff but stops saying
"No ELM found. Please check connection and try again" ny help would be greatly appreciated.
