n2frets
Vehicle: Ford F150 KR 3.5l 375HP 2018
Post by n2frets »
Signed up 2 days ago and I received this email
Welcome to "FORScan forum"
Inbox
no-reply@forscan.org
May 9, 2021, 5:10 PM (2 days ago)
to me
Welcome to FORScan forum forums
Please keep this email for your records. Your account information is as
follows:
Username: deleted
Board URL: https://forscan.org/forum
Your account is currently inactive and will need to be approved by an
administrator before you can log in. Another email will be sent when this
has occurred.
If you have questions about registration and approval process, please check
our FAQ:
https://forscan.org/faq.html#forum
Your password has been securely stored in our database and cannot be
retrieved. In the event that it is forgotten, you will be able to reset it
using the email address associated with your account.
Thank you for registering.
Regards,
FORScan Team
Website says it usually only takes 8 hours to get the second email but no more than 24 hours. It has been 48 hours. Am I missing something.
Post by tractmec »
n2frets wrote:
Tue May 11, 2021 11:24 am
Inbox
to me
follows:
Username: deleted
has occurred.
our FAQ:
Regards,
FORScan Team
This post to the "Whats New Link on the Home Page Here https://forscan.org/index. Might give you an answer?
What's new Home Products Documentation FAQ HowTo Forum Contact Us Русский
What's new in FORScan
May 03, 2021 - Limited support in the period of May 01 - May 10
Due to nationwide holidays from May 01 to May 10 and partial unavailability of the development team, some requests to support may experience much greater than usual processing time (up to several days instead of usual 24 hours). We are sorry for the inconvenience.
Give it another day or so and everyone should be back to work!
n2frets
Post by n2frets »
Ah, thank you. I missed that.
andresranger3.2
Vehicle: ford ranger 3.2 200cv 2014
Post by andresranger3.2 »
que tal , cambie de pc y necesito la clave de la licencia extendida, que datos necesita? gracias
Post by tractmec »
andresranger3.2 wrote:
Tue May 11, 2021 7:11 pm
How about I change pc and I need the extended license key, what data do you need? Thank you
Translated with google translate!!
The new computer will need to generate a new Trial License key with the Hardware ID of the new computer!
Paid licenses can be transfered to another computer if the license is uninstalled from the old machine and the original Activation Code is transferred to the new machine!
Qué tal si cambio de PC y necesito la clave de licencia extendida, qué datos necesitas? Gracias
Traducido con traductor de google !!
La nueva computadora deberá generar una nueva clave de licencia de prueba con el ID de hardware de la nueva computadora!
Las licencias pagadas se pueden transferir a otra computadora si la licencia se desinstala de la máquina anterior y el código de activación original se transfiere a la nueva máquina.
F.Pelaez
Vehicle: Ford Mondeo,TDCI 2.0/130cv, 2004 y Ford Fusion TDCI 1.4/70cv
Post by F.Pelaez »
Mi laptop doesn't work correctly. Can I change the laptop downloading FORScan and using my extended license?
Post by tractmec »
F.Pelaez wrote:
Mon May 17, 2021 5:58 pm
You will have to generate another license with the "changed" laptop. Trial licenses are Tied to a specific Hardware ID!
centralmax
Vehicle: f150, 3.5 ecoboost, 375hp, 2018
Post by centralmax »
My windows computer cant "load license key" so how do i copy and paste the activation code? Which lines are the correct "activation code"
Post by tractmec »
centralmax wrote:
Tue May 18, 2021 5:12 pm
That's a bit of a complicated regedit procedure not for the faint of Windows heart!! I seems you Know what folder you downloaded the "FORScanLicense.key" file to and most people seem to have trouble finding the .key file using the "Load License Key" button in Forscan. It is a matter of navigating to the file within Forscan Itself!
Have a look at this and see if it works viewtopic.php?f=5&t=4529&start=10 Once you find the file, High-lite it and click OK and Forscan does the Copy and Paste!
eric manasseh
Vehicle: Ford 2.0 focus 2008
Post by eric manasseh »
Gmail: manasseheric4@gmail.com
