Andyfocus
Post by Andyfocus » Wed Feb 06, 2019 4:21 am
bgeyer82 wrote:
Tue Feb 05, 2019 11:51 pm
Hello guys, hoping for some help here. I received my Extended License, and when I load it, it restarts, but when it comes back up, I don't have the confirmation that the license is still there. It also show an activation key. How do I get this to work? I have version 2.3.19. Thank you
what windows are you running ?
have you tried running forscan as admin (right click run as admin on windows 10 ) , if it remembers the id goto properties and click next to run this program as an admin on the compatability tab(windows 10 ) .
Wfo
Vehicle: Raptor 3.5L 2018
Post by Wfo » Sun Feb 10, 2019 3:12 pm
I am having this same problem with windows 10. System is not recognizing extended license. Suggestions?
danou27
Vehicle: ford fusion 1.4 durashift 2004
Post by danou27 » Mon Feb 11, 2019 10:19 pm
salut personnelement j'ai tout essayer pour mettre une licence etendue , rien a faire il ne me met qu'une version trial alor que la procedure a parfaitement ete faite , quelqu'un aurait-il une solution svp , aussi si une personne a la solution pour le boitier TCM pour ford fusion , le code erreur est p0949 tcm asm apprentissage inachevé merci
f-wolf
Post by f-wolf » Mon Feb 11, 2019 10:40 pm
Just have a read here ... it may help you. :?:
http://forscan.org/forum/viewtopic.php? ... f=5&t=5775
RYM6746
Vehicle: Fiesta petrol 1.2 60Kw 2010
Post by RYM6746 » Wed Feb 13, 2019 9:44 pm
Hi I'm sure this has been asked a 100 times already but I am new to forscan software. I have successfully registered my 2 month trial extended licence but I work in the motor trade and programmes many ford keys with the IDS. I prefer to use forscan as its a simpler proceess. How do I go about getting a permanent extended licence. I am happy to contribute financially for the service?
Thanks again for your help and the great software. :D
f-wolf
Post by f-wolf » Thu Feb 14, 2019 8:18 pm
Hi there ...
Try this :
memberlist.php?mode=contactadmin
Ps ... You can renew your 2 month trial extended licence any time before or after it expires !
proudf150driver
Vehicle: 2017 ford f150 supercrew
Post by proudf150driver » Sun Feb 17, 2019 3:16 pm
Hi I already re generated a extended licence , when it expires again is there a procedure to get a permanent extended licence or do I have to keep re generating one I'm not that great with computers I hope it's ok I posted this here thanks kindly
Andyfocus
Post by Andyfocus » Sun Feb 17, 2019 6:09 pm
just do the same again and generate another licence when that one runs out ;) .
since writing this licences have been changed unsure if this still applies until i try it again myself.
wig073
Vehicle: ford v8 1999
Post by wig073 » Wed Feb 20, 2019 2:53 am
Well Andy if you can only respond with figjam comments then your not the person to answering questions
wig073
Post by wig073 » Wed Feb 20, 2019 2:55 am
Andyfocus wrote:
Wed Feb 06, 2019 4:18 am
wig073 wrote:
Wed Feb 06, 2019 3:34 am
where is the about page to get the hardware id?
if you can not even find the simple things i think this is not for you , i would go to someone who knows what their doing .
Figjam
