f-wolf
Vehicle: *** Ford ***
Post by f-wolf » Wed Jan 30, 2019 8:01 pm
Dai un'occhiata qui:
Take a look here:
https://forscan.org/download.html
Boland1776
Vehicle: F150, 5.4l, 2010
Post by Boland1776 » Fri Feb 01, 2019 12:41 am
Does the extended license last for 2 or 3 months? If I generate an extended license when does the clock start ticking (from the time I create it or from the date I add it in FORScan?
f-wolf
Post by f-wolf » Fri Feb 01, 2019 11:04 am
From the time you create it ...
2 Months.
lennie76
Vehicle: 2012 f250 ford
Post by lennie76 » Tue Feb 05, 2019 3:40 am
Trying to get the extended license and I get the following error:
Unable to generate license key. Please make sure Hardware ID is copied correctly
I have used the copy to clipboard function, manually copied and manually typed the ID.
I always get the same result
2.3.19 beta
Used the generator form page on multiple computers, using different browsers and always received the same error.
Andyfocus
Post by Andyfocus » Tue Feb 05, 2019 9:49 am
2.3.19 beta
when entering the id make sure their are no spaces before or after it .
if still not working pm me your details and il give it a go for you .
lennie76
Post by lennie76 » Tue Feb 05, 2019 12:50 pm
Not sure what changes, but it worked after about 2
Minutes
bgeyer82
Vehicle: 2013 Ford F150 5.0
Post by bgeyer82 » Tue Feb 05, 2019 11:51 pm
Hello guys, hoping for some help here. I received my Extended License, and when I load it, it restarts, but when it comes back up, I don't have the confirmation that the license is still there. It also show an activation key. How do I get this to work? I have version 2.3.19. Thank you
wig073
Vehicle: ford v8 1999
Post by wig073 » Wed Feb 06, 2019 3:34 am
where is the about page to get the hardware id?
Andyfocus
Post by Andyfocus » Wed Feb 06, 2019 4:18 am
Minutes
could have been just high demand time and a few people registering .
Andyfocus
if you can not even find the simple things i think this is not for you , i would go to someone who knows what their doing .
