Focus 1.6Tdci -09 Regeneration problem
Posted: Tue Aug 28, 2018 7:44 am
by rehtori74
Hey,
I have problem with regeneration. Forscan shows fault P2458 and engine regeneration every 10-20km cycle.
Regeneration temperature is about 550-600c° highway speed(120kmh) and that takes time about 10min. dpf differential pressure sensor value is ~12Kpa (highway speed)
I trye stand still regeneration, but did not go through.
dpf filter has been changed to 15000km then.
Need help.
Tanks!
Re: Focus 1.6Tdci -09 Regeneration problem
Posted: Fri Nov 23, 2018 1:41 pm
by Smoelfespark
I have the same problem.
I have cleaned the DPF with JLM cleaning fluids. Replaced cracked DPF pressure hoses. Ordered a new pressure sensor.
The mileage is very bad, and the motoroil is being filled with diesel.
It all started with 3 bad injectors.
EGR is blocked.
Best regards
