IPC Programming Not Working on 2019 Super Duty (Forscan 2.3.16 beta)
4jtspt
Vehicle: F250 super duty, diesel, 6.7, 2019
Re: IPC Programming Not Working on 2019 Super Duty (Forscan 2.3.16 beta)
Post by 4jtspt » Thu Feb 27, 2020 12:12 am
Texas78028 wrote:
Fri Jan 24, 2020 1:11 pm
I am using Forscan version 2.3.28 on my windows 10 laptop. I cannot access any module on my 2019 Superduty. I get the message, "Sorry, you need an extended license to run this function" for every selected module.
I've searched around this forum and have read that I do not need an extended license. I am new to Forscan… am I doing something wrong?
EDIT: I ended up buying an extended license for $10 for 1 year. I had no idea it was that cheap. All good now!
so im new to forscan but 30 years in the automotive/heavy truck industry as of 2 weeks ago. today i just ordered the forscan recommended obd2. will I need to purchase a license to change things like bambi mode or others? what can I do with the non license forscan. I have V2.3.29 on windows 10 laptop. thank you, and cant wait to start to use this.
tmorris
Vehicle: Expedition Fx4 3.5L Ecoboost 2019
Post by tmorris » Thu Feb 27, 2020 12:18 am
Go to the Products page and you can get a 2 month Extended License for free. There are also options to purchase a 1 year, 3 year, 5 year, or lifetime license.
Vehicle: *** Ford ***
Post by f-wolf » Thu Feb 27, 2020 1:00 am
Its all here: https://forscan.org/download.html
rbkteam
Vehicle: Ford Transit Custom MY20 130hp
Post by rbkteam » Tue Mar 31, 2020 2:10 pm
Confirmed issues with the 2020 Transit Custom IPC Module, I can read well but it cannot be writed. Other modules works fine.
Win7
Forscan V 2.3.31 beta for Windows
Interface: OBD2 Maozua MZ327
sevlor
Vehicle: Fusion, 1.6, 2013
Post by sevlor » Sun Apr 05, 2020 4:05 am
Having the same issue of unable to write to IPC on 2019 Fusion Sport, windows 10, forscan 2.3.31 (latest beta) and using wired adapter with MS/CAN switch.
nrm101
Vehicle: Mustang, v8 , 2019
Post by nrm101 » Tue Apr 21, 2020 2:35 am
Not sure this will help anyone or not, I was doing a digital dash upgrade in 2019 mustang, and i had already had a Profile saved in forscan, every change i tried to make on the new IPC was failing, either at 3x% or 100% then get a failed message in the log. I final found that if i started forscan and Said NO to my already configured profile, and let it scan everything again, and then saved under a new profile name (v2 My19...) i was finaly able to program the IPC.
Hope this helps someone...
rbkteam
Post by rbkteam » Wed Apr 22, 2020 5:22 pm
In my case itried erasing previous profiles and it didn't work.
Today i've a quick test with the new forscan update and also don't work.
I'll try with calm in a days 🤞🏼
Post by fordsmax471 » Wed Apr 22, 2020 5:32 pm
View windows hidden files and folders
car profiles are in this file
C:\Users\AppData\Roaming\FORScan\vehicles
FORScan v2.4.0/Els27 v4/Elitebook 840 G6/Win10 Pro ver.2004
rbkteam
Post by rbkteam » Thu Apr 23, 2020 8:32 pm
Nothing!! :( :(
Contender
Vehicle: 2018 Ford F250 6.7
Post by Contender » Fri May 08, 2020 11:20 pm
Had same IPC issue on 2018 F250
When connecting say no to the option to pull up the Identified model of your truck and this will write the complete configuration and pull up all options Including the IPC
Changing to a S&B 60 gal fuel tank and needed to adjust DTE through IPC file
Worked for me.....good luck
