IPC Programming Not Working on 2019 Super Duty (Forscan 2.3.16 beta)
lynam05
Vehicle: 2019 F250 6.7 lariat
Re: IPC Programming Not Working on 2019 Super Duty (Forscan 2.3.16 beta)
Post by lynam05 » Tue Aug 13, 2019 2:51 am
I'll try it in the morning.. this has been driving me crazy past few days.. I'm hoping for the same issue.. easy fix
Mine
Vehicle: Mustang, 5,0, 421 PS, 2017
Post by Mine » Thu Aug 15, 2019 7:17 am
I have this with my Ecosport, i can't switch any Number.
I would like DRL and Autolock on the Copickt menü. Evereytime it's come: contact the developer.
On my Mustang it's works.
Best Regards
Mine
lynam05
Post by lynam05 » Sat Aug 17, 2019 2:30 pm
Has anyone had any progress yet?
We kindly ask everyone who experience this problem one newest models and latest version of FORScan send us debug information as described here:
https://forscan.org/contactus.html#debug_info
You will help to improve the project, and we will provide you with a test build that has the problem fixed.
[/quote]
fireice
Vehicle: Lincoln Navigator 2018
Post by fireice » Mon Aug 26, 2019 3:19 pm
One more vote for supporting writing to IPC for 2018 Navigator. Currently it does not work with the latest version of Forscan.
Thank you
bherron1
Vehicle: 2019 F150 XL 3.3 reg cab LB
Post by bherron1 » Sun Sep 15, 2019 5:08 pm
FORScan wrote:
Sat Sep 08, 2018 11:57 pm
FORScan recognizes modules by their part numbers, modules of new models usually have new part numbers that have to be added to the database periodically, what happens in new FORScan releases. Programming 2019 F-Series IPCs is supported in FORScan 2.3.17 (no public release yet, but everyone can request a test build from us in PM or by email).
However, what f-wolf and twisterrescue explained is actual for some brand new models of 2018 and 2019 model years, specifically:
2018 Expedition (U553)
2018 Navigator (U554)
2018 Ecosport (B515)
2018 Ka/Figo (B562)
2018 Ranger (P375)
2018 Everest (U375)
2019 Transit Connect (V408 MCA)
2019 Focus (C519)
(most likely, the list will grow)
In contrast to Ford IDS, FORScan will support these models (in fact, already does), but configuration and programming for some modules (first of all, for IPC) may not work. We are going, however, make these functions available in the future, although so far it is not clear how much time it will take.
We have sticked the thread as the information may be helpful for many users.
Oh boy I just changed values his morning in Fordscan on my 2019 F150 and not sure if I have the correct version of Fordscan as stated above 2.3.17
I noticed on the spread sheet for 2015 to 2019s it had old IPC new IPC and newer IPC I stopped the door ajar chime engine running and key in engine off, door chime and it worked, go figure. Should I continue or wait for the newer version. I used a ELS27 OBD connector with no HS, MS switch.
rstrainii
Vehicle: F250 6.7 2019
Post by rstrainii » Mon Sep 23, 2019 3:57 pm
I cannot replicate the problem my 2019 sees all the modules.
Dude's Diesel
Post by Dude's Diesel » Sat Oct 19, 2019 2:26 pm
Has anyone with a 2019 have an error when trying to back up APIM? Link is attached with picture.
viewtopic.php?f=5&t=11101&p=38006#p38006
Mattm400
Vehicle: 2019 f250 6.7 diesel lariat.
Post by Mattm400 » Fri Nov 15, 2019 3:14 am
Same issue here 2019 F250, OBD-MX . I can change any module EXCEPT IPC. I recognize it but cannot make changes. It gives error message & reverts to factory.
Mr.Boobadoo
Vehicle: 2019 F450 CC 6.7L
Post by Mr.Boobadoo » Sat Jan 18, 2020 7:55 pm
I have 2019 F450 xlt. I can change all IPC programs on the master sheet except for last, the IPC quick boot.
Texas78028
Vehicle: 2019 Ford F250
Post by Texas78028 » Fri Jan 24, 2020 1:11 pm
I am using Forscan version 2.3.28 on my windows 10 laptop. I cannot access any module on my 2019 Superduty. I get the message, "Sorry, you need an extended license to run this function" for every selected module.
I've searched around this forum and have read that I do not need an extended license. I am new to Forscan… am I doing something wrong?
EDIT: I ended up buying an extended license for $10 for 1 year. I had no idea it was that cheap. All good now!
