2008 F250 6.8 Battery Drain
- Vehicle: Escape 2.3 hybrid 2006
The PCM relay in the fuse box stays warm after the engine is turned off. I can disconnect the large connector from the PCM and the relay clicks and stays off. Reconnecting the connector re-energizes the relay. Any clues would be appreciated.
