Auto Lock 2018 F150
milzie
Vehicle: 2018 F150, 3.7 Ecoboost
Auto Lock 2018 F150
Post by milzie » Wed Jun 06, 2018 9:16 pm
Im trying to turn the auto lock feature of my 2018 F150 Lariat off......when you start driving, all doors lock.....drives me crazy that you need to stop, go into park, shut vehicle off, then open drivers door for all the doors to auto unlock.
Anyways, From the spreadsheet, I see that BCM 726-15-01 needs to be changed. Spreadsheet shows for lines. I tried them all separate, and auto lock always happened.
Am I missing something else that I need to change? Any help is appreciated.
Vehicle: *** Ford ***
Re: Auto Lock 2018 F150
Post by f-wolf » Thu Jun 07, 2018 12:06 am
milzie
Post by milzie » Thu Jun 07, 2018 5:52 pm
None of those things work on a 2018. They have removed it from the menu so it cant be turned off. Those things are only applicable up to 2017.
I got the Forscan figured out. Wrote the file, and for whatever reason, I needed to deselect auto UNlock from the display on my truck. Once I did that, all is working well.
codygjohnson
Vehicle: F150, 5.0l
Post by codygjohnson » Wed Jun 20, 2018 2:11 pm
If you don't mind sharing: Which line did you change, or did you change values in all four auto lock lines? Did you use value 0 for disable or value 2 for inoperative? I've got the same issue (one of the reasons I picked up forscan).
Bodaddy
Vehicle: F150 Lariat, 5.0L V8, 2016
Post by Bodaddy » Sat Aug 25, 2018 1:16 pm
Hey everyone, my friends 2018 F150 was auto locking the doors all the time and he couldn't turn it off (like I can in my 2016).
The values I changed in his truck to bring the auto lock setting back to Advanced Settings -> Vehicle -> Locks was:
IPC 720-01-01 xxx* xxxx xxxx Add 1 to the current value of *. If 0 make 1, if 6 make 7, if E make F, etc.
Once I did that the checkbox appeared in his settings. We unchecked auto lock, left auto unlock selected and it never locked the doors when driving.
Hope this helps
ravedian
Vehicle: Raptor, ecoboost, 3.5L, 2019
Post by ravedian » Wed Sep 11, 2019 2:45 pm
Just to add some info. I was able to do this modification on my 2019 raptor, worked fine. Thanks for posting
k5rcd
Vehicle: ford f150 5.0l v8 2018
Post by k5rcd » Wed Sep 11, 2019 6:10 pm
Hope this helps
A million thanks.
Worked perfectly on my 2018 F 150 to override that annoying feature.
Randy
south Texas
B737
Vehicle: 2020 F150 5.0 Platinum
Post by B737 » Fri Jan 31, 2020 2:08 pm
I just did this on my 2020 F150 Platinum, Changed the E to an F, it made the menu item appear in settings and it is working fine. many thanks.
chamacblah
Vehicle: Mazda 3 2.0l 2005
Post by chamacblah » Fri Feb 07, 2020 2:46 am
For my 2020 F150 XLT, not spread sheet was required, in the regular module (not the as built module) its in plain text
Auto lock option was disabled, i enabled it and its done.. works great
