Ford escape hates hot weather
Alkis
Vehicle: Ford Escape 2009 limited
Post by Alkis » Sat May 26, 2018 2:49 am
I'm having a crazy problem with my 2009 Ford Escape limited 3.0l. For two years now whenever the temperature is ~90 degrees the antitheft system goes off and refuses to crank. If I open the doors and pull it under shadow for 20 minutes, everything is fine. I took it to 2 different dealerships but they couldn't replicate the problem...
When this happens the antitheft light blinks rapidly and then gives code 16. During that I have dashes in my mileage and I cannot connect any kind of diagnostic software to pcm. When it turns back on the only error I'm getting is P1260.
I'm trying through elimination to figure out what is going on. So till now I tried the following.
1. Replace battery and checked the ground.
2. I installed a remote starter with pats bypass to check if the pats transceiver has any problem. It doesn't start even with the remote start when is hot outside...
3. Removed the instrument cluster, put it in my cooler to cool it down, attached it again... nothing (I know its funny but I'm desperate)
4. Removed the PCM did the same with the IC but no luck.
5. Checked all fuses, everything seems ok.
6. I have both keys nothing work when it's hot outside.
7. Fuel pump and cluster both working when I turn the key.
So any help or ideas are welcome...
Vehicle: *** Ford ***
Re: Ford escape hates hot weather
Post by f-wolf » Sat May 26, 2018 4:07 am
I hope this will help you ??
https://autoservicecosts.com/obd2-codes/p1260/
Also ... I got one of these:
Works on my Ford and Wife's Mazda
Cpil Tester .jpg (52.6 KiB) Viewed 1158 times
*** AUGOCOM Auto Lock Inspection Loop EZS Checker Immobiliser System OBD Fast Tester ***
Found on EBAY
The small LED will pulse-flash one time or more ( Depending on your brand of car )
The test unit will tell you if there is a signal / communication ( PATS ) at the coil near the ignition key when you turn the key to on ...
Coil Checker.jpg (98.29 KiB) Viewed 1158 times
Alkis
Post by Alkis » Sat May 26, 2018 2:26 pm
Thanks for the response but I wonder... if it was the coil receiver on the ignition the problem, shouldn't the remote start that bypass the immobilizer and doesn't need a key, start the car?
Alkis
Post by Alkis » Sat May 26, 2018 7:45 pm
===PCM DTC Error===
Unable to read DTC
===END PCM DTC Error===
===OBDII DTC None===
Successful DTC reading, no error codes found
Module: On Board Diagnostic II
===END OBDII DTC None===
===APIM DTC U0100:00-2B===
Code: U0100 - Lost Communication With ECM/PCM A
Status:
Module: Accessory Protocol Interface Module
===END APIM DTC U0100:00-2B===
===RCM DTC U0100:00-8B===
Status:
- Malfunction Indicator Lamp is On for this DTC
===END RCM DTC U0100:00-8B===
===OCS DTC None===
Module: Occupant Classification System Module
===END OCS DTC None===
===4X4M DTC U0100-60===
Code: U0100 - Lost communication with the PCM
Status:
Module: 4X4 Control Module
Note:
DTCs that start with 'U' are faults which occur during module-to-module communication.
Modules should never be replaced based only on a 'U' code. These codes do not always indicate a problem, and can be caused by normal diagnostic functions, carried out on the vehicle.
===END 4X4M DTC U0100-60===
===4X4M DTC U0121-60===
Code: U0121 - Lost Communication With The ABS Control Module
Status:
===END 4X4M DTC U0121-60===
===ABS DTC Error===
Unable to read DTC
Module: Antilock braking system
===END ABS DTC Error===
===PSCM DTC U0100-6F===
Status:
Module: Power Steering Control Module
Note:
===END PSCM DTC U0100-6F===
===IC DTC U0100-60===
Status:
Module: Instrument Cluster
Note:
===END IC DTC U0100-60===
===IC DTC U0121-60===
Status:
===END IC DTC U0121-60===
===PAM DTC None===
Module: Parking Aid Module
===END PAM DTC None===
===FCIM DTC None===
Module: Front Controls Interface Module
===END FCIM DTC None===
===FDIM DTC None===
Module: Front Display Interface Module
===END FDIM DTC None===
===HVAC DTC None===
Module: Heating Ventilation Air Conditioning
===END HVAC DTC None===
===ACM DTC None===
Module: Audio Control Module
===END ACM DTC None===
===GEM/SJB DTC None===
Module: Generic Electronic Module / Smart Junction Box
===END GEM/SJB DTC None===
My logs if someone can figure out anything
lmlaster@yahoo.com
Vehicle: 2015 Ford Focus Electric
Post by lmlaster@yahoo.com » Sat Jul 20, 2019 4:27 pm
Did you ever figure this out. I am having problems with my Ford Focus Electric. Obviously heat related. My dealer has had the car for 3 weeks, working with Ford to figure it out.
http://www.myfocuselectric.com/forum/vi ... php?t=4860
Do you have any insight?
NWIndiana White Lightning
denbo
Vehicle: ford focus 16 zetec
Post by denbo » Sun Jul 21, 2019 7:46 pm
Borrow the wife,s hair dryer and warm up the ecu. They don,t get hot enough to harm the unit see if you can get it to misbehave.
