2017 Super Duty - Wish List
Bull30213
Vehicle: 2017 Super Duty 6.7
Post by Bull30213 » Sun Apr 01, 2018 6:15 am
First of all thanks to the authors of this program and the folks on the F150 forum for the detailed spreadsheets. I've done all the mods I can with the data that's's out there now, but I still have a 'wish list' of configurations I haven't found yet. I'm posting them here in case somebody has figured any of them out, and as I keep experimenting on my own truck I'll update this post with what I can find that works.
For reference this is on a 2017 F350 Lariat 6.7 SYNC3.
Enable auto-folding mirrors. SOLVED!
Enable Nav entry at any speed. SOLVED!
Vehicle Speed Limiter - change from 152 km/h
OEM spot lights (in mirrors) - disable turning off at 5mph, enable at any speed.
Cargo light - disable turning off at 5mph, enable at any speed.
Enable rear view camera to be turned on manually (my '17 Explorer has a button for this, my F350 does not).
Enable rear view camera at any speed.
Change timeout value for cargo & bed lights.
Change steering wheel media buttons (fwd / back) to function as Seek instead of Preset Skip. The hard buttons on the center console behave this way, the steering wheel buttons should be able to as well.
Enable cruise control to command high idle. Larger trucks and some Super Duty trucks can do this from the factory, I think it is tied in to the PTO functions.
Display inside (cabin) air temp on Sync 3 display.
romanservices
Vehicle: F350, 6.7L 2017
Re: 2017 Super Duty - Wish List
Post by romanservices » Mon Nov 05, 2018 4:41 am
I've got a 17 DRW F350 - mainly looking to enable the aux camera while in motion. I noticed that the newest sync update allows me to select the camera without having to switch to reverse which is nice however I need to see my trailer behind my 5th wheel while traveling. This is my first time using Forscan however not my first time doing this stuff.
Do you know if the nav in motion mod also lets you view a camera in motion?
Bull30213
Post by Bull30213 » Mon Nov 05, 2018 2:58 pm
Sadly, it does not. I'm still looking for that one too.
seanaoneill13
Vehicle: 2018 F250 Diesel
Post by seanaoneill13 » Wed Nov 07, 2018 7:56 pm
This can be done with a hardware modification- cut 1 wire, bridge the cut side to an adjacent one that provides +12V all the time, and you can turn the lights on at any speed. They will also stay ON if you do not turn off, but at least they work.
Spot Light wiring modification
Dbreames
Vehicle: 2019 F350 King Ranch
Post by Dbreames » Wed Jul 24, 2019 11:48 pm
i am considering doing some mods to my 2019 F350 King Ranch. the main two i am interested in doing is Auto Folding Mirrors when ignition is off, enter Nav Commands at any speed. is there any help you can share with me. I will be purchasing the following Plug
FORScan OBD2 Adapter, OHP ELMconfig ELM327 Scanner USB Interface, Ford Cars F150 F250 and Light Pickup Truck Accessories Scan Tool, Code Reader w/ MS-CAN HS-CAN Switch, Windows Only
thank you in advance for being a Noob
Toonces
Vehicle: 2018 Ford F150 5.0L V8 BlackOps
Post by Toonces » Wed Jul 31, 2019 1:54 am
@Bull30213, did you ever figure out how to do this? I'm trying to do the same thing on my 2018 F150 (Sync3), but haven't had any success finding any information online.
Bull30213
Post by Bull30213 » Wed Jul 31, 2019 2:18 am
I didn't. I worked on it for a little but longer without success. I then loaned my OBD tool out to a friend and haven't gotten it back yet. I need to get it back and finish this up. Sorry.
124Shark
Vehicle: 2017 F 350 6.7 power stroke
Post by 124Shark » Wed Jul 31, 2019 8:56 pm
add def filter % as well
glendar100
Vehicle: 2019 ford f250 King Ranch Diesel
Post by glendar100 » Fri Aug 09, 2019 4:44 pm
turn on Engine Breaking full time.
Bull30213
Post by Bull30213 » Fri Aug 09, 2019 5:12 pm
@124Shark
There is a code to get the DPF Filter percentage, at least as a screen in the Truck menu. From the 2017 Super Duty codes spreadsheet:
Feature Name: Add DPF Filter % to screen
Module: IPC
Key Position: 720-07-02
Example Value: x7xx xxxx
New Value: xFxx xxxx
Notes: This adds the DPF % screen to the Truck Information screen. Some trucks will report a camera error after making this modification. To avoid that, make your update according to the following: If your original default value is 0, change to 8; if 1, change to 9; if 2 then A; if 3 then B; if 4 then C; if 5 then D; if 6 then E, if 7 then F (as shown).
