Multible DTC with same timestamp
s_ejlertsen
Vehicle: Ford S-Max, 2.0 Tdci, 2012
Post by s_ejlertsen » Sat Feb 17, 2018 8:36 pm
Hi FORScan,
I have an Ford S-Max 2.0 tdci from 2012. Today I got "Engine mal function in the display, and the engine went in soime sort of safe program. I got the following readout using FORDScan:
===PCM DTC P0120:00-2F===
Code: P0120 - Throttle/Pedal Position Sensor A Circuit
Status:
Possible causes :
Electrical connectors not fully engaged
Wiring Harness Short to Battery or Short to Ground
Faulty Sensor
Check for continuity shorts to ground and battery positive.
Inspect connectors for signs of damage, water ingress, corrosion, etc.
Freeze Frame :
-GLOBTIM: 166888624 sec - Global real time
-TOTDIST: 203289.0 km - Total Distance
-MAINECUV: 14.50 Volt - Main ECU voltage supply
-ESTSERUN: Yes - Engine status - engine running
-ESTSECRK: No - Engine status - engine in crank
-INCARTMP: 30 °C - In car temperature
-OUTTMP: 6 °C - External Temperature From Sensor
===END PCM DTC P0120:00-2F===
===PCM DTC P2138:00-2F===
Code: P2138 - Throttle/Pedal Position Sensor/Switch D / E Voltage Correlation
Status:
Freeze Frame :
===END PCM DTC P2138:00-2F===
===PCM DTC U0284:00-2E===
Code: U0284 - Lost Communication with Active Grille Air Shutter Module A
Status:
Freeze Frame :
===END PCM DTC U0284:00-2E===
===PCM DTC P1632:08-2E===
Code: P1632 - Smart Alternator Faults Sensor / Circuit
Additional Fault Symptom:
- Bus Signal/Message Failures
Status:
Freeze Frame :
===END PCM DTC P1632:08-2E===
===PCM DTC U0415:86-AE===
Code: U0415 - Invalid Data Received From ABS Control Module
- Signal Invalid
Status:
- Malfunction Indicator Lamp is On for this DTC
Freeze Frame :
===END PCM DTC U0415:86-AE===
===PCM DTC P1935:08-2E===
Code: P1935 - Brake Switch/Sensor Signal
Status:
Freeze Frame :
===END PCM DTC P1935:08-2E===
===PCM DTC U0129:87-2E===
Code: U0129 - Lost Communication with Brake System Control Module A
- Missing Message
Status:
Freeze Frame :
===END PCM DTC U0129:87-2E===
===PCM DTC U0155:00-2E===
Code: U0155 - Lost Communication With Instrument Panel Cluster Control Module
Status:
Freeze Frame :
===END PCM DTC U0155:00-2E===
===PCM DTC U0418:08-2E===
Code: U0418 - Invalid Data Received from Brake System Control Module A
Status:
Freeze Frame :
===END PCM DTC U0418:08-2E===
===PCM DTC P193D:82-2E===
Code: P193D - Cruise Control Multi-Function Input Signal
- Alive/Sequence Counter Incorrect/Not Updated
Status:
Freeze Frame :
===END PCM DTC P193D:82-2E===
===PCM DTC P060D:00-2F===
Code: P060D - Internal Control Module Accelerator Pedal Position Performance
Status:
Freeze Frame :
===END PCM DTC P060D:00-2F===
===PCM DTC U0001:00-AE===
Code: U0001 - High Speed CAN Communication Bus
Status:
Freeze Frame :
===END PCM DTC U0001:00-AE===
===PCM DTC P2125:00-2F===
Code: P2125 - Throttle/Pedal Position Sensor/Switch E Circuit
Status:
Freeze Frame :
===END PCM DTC P2125:00-2F===
===PCM DTC U0126:00-2E===
Code: U0126 - Lost Communication With SASM
Status:
All DTC's has the same GLOCTIM and same TOTDIST. I suspect just one of the DTC's has caused the problem, and triggered the remaining DTC's. But since they all have the same time stamp, I don't know which were the first. Is there any way to find which were the first? Or can I change some settings, so it triggeres in milli seconds instead of seconds?
Best Regards
Simon
denbo
Vehicle: ford focus 16 zetec
Re: Multible DTC with same timestamp
Post by denbo » Sun Feb 18, 2018 11:10 am
I would start with brake switch. test it and replace as this is a safety issue. They are usually a 2side switch. Brake light on one side, signal to ecm on other.
s_ejlertsen
Post by s_ejlertsen » Sun Feb 18, 2018 8:19 pm
Hi Danbo,
Thank you for your reply.
Currently I'm suspecting a fault in the "Throttle/Pedal" sensor, since it is mentioned in the DTC describtions several times.
Have you seen these errror codes before and found the break switch to be the problem, or is it something else that points in that direction?
Best Regards
Simon
denbo
Post by denbo » Mon Feb 19, 2018 6:54 pm
You will lose the pedal when it goes into limp, because of the original fault. Fix that and the pedal should come back. I f you think of it logically, if the ecu cannot see what the brakes are doing it will not let you set the c.control nor will it let you go speeding off. SAFETY
s_ejlertsen
Post by s_ejlertsen » Mon Feb 19, 2018 8:40 pm
Hi Denbo,
I see what you mean. I will replace the switch just to be sure.
Best regards
Simon
