hexadecimal calculation, entering into FORScan
cbeami
Vehicle: Ford Everest Trend 2017
Post by cbeami » Fri Feb 16, 2018 8:01 am
Hi all.
Below is the instructions for disabling chimes (2017 Ford Everest) when key in ignition, not on and door is open.
IPC
720-02-01 xx*x xxxx xxxx
To disable, subtract 8 from your current value there where the asterisk is.
When I go into my IPC module I get:
720.02.01: FF25 3C54 0EEC
Using the above instructions what do I enter when 2 - 8 = -6 (hexadecimal).
Im not sure how to disable the chimes.
Many thanks in advance.
Craig
cbeami
Re: hexadecimal calculation, entering into FORScan
Post by cbeami » Fri Feb 16, 2018 9:05 am
Just thinking... can I enter a -6 or is there another character I'm suppose to use.
thanks
ThatOneDude
Vehicle: 2007 Ford F-150 SuperCab 5.4L 3V 4WD
Post by ThatOneDude » Fri Feb 16, 2018 9:33 am
Every vehicle has different settings. You should be 100% sure that the instructions were given for your vehicle. There are no negative numbers in hex.
1996 Lincoln Town Car Executive
2003 Ford Crown Victoria Police Interceptor
2011 Ford Crown Victoria Police Interceptor
cbeami
Post by cbeami » Fri Feb 16, 2018 11:24 am
many thanks. Maybe I just live with the chime.
thanks
