Programming error on 2013 Taurus SHO
FiveLeeter918
Vehicle: 2013 Ford Taurus SHO
Post by FiveLeeter918 » Sun Jan 14, 2018 4:50 am
Hey guy! Been lurking a while and finally felt comfortable enough to delve into this. I have a 2013 Ford Taurus SHO PP, 401a. I have a ELM327 hardwired adapter with MS/HS scan switch. Running Windows 7 on my laptop and a registered license.
And
When I log in as COM it boots up, displays all the modules for IPC, Radio, Drivers seat, etc. So i know it works.
However, I am trying to reprogram my IPC using the same codes others on here have used and keep getting an error.
Tried with both switch positions, in MS it hangs up immediately with just the service interrupt, in HS I get both errors.
- Lee
2013 Taurus SHO PP
AWD gauge, EQ presets, Nav in Motion, Double Honk Deactivated, Signal Flash increased to 5, Engine hours enabled, DRLs enabled
denbo
Vehicle: ford focus 16 zetec
Re: Programming error on 2013 Taurus SHO
Post by denbo » Sun Jan 14, 2018 12:02 pm
Do you have the extended license?
FiveLeeter918
Post by FiveLeeter918 » Sun Jan 14, 2018 1:28 pm
Yes I do, it shows good until March in the settings.
- Lee
2013 Taurus SHO PP
denbo
Post by denbo » Mon Jan 15, 2018 8:20 pm
How can you have a 2 month license lasting until march? But anyway back on topic, Have you got battery back up or charger connected, voltage is critical.
FiveLeeter918
Post by FiveLeeter918 » Mon Jan 15, 2018 8:22 pm
I just got it last week, and I guess because it's 60 days and with February being short a few days it doesn't expire until March 2nd.
My battery is good, and I've gotten the same message no matter if the key is off, key is on, or engine is running.
- Lee
2013 Taurus SHO PP
FiveLeeter918
Post by FiveLeeter918 » Tue Jan 16, 2018 2:15 am
Programming while engine running got her done. Sweet.
- Lee
2013 Taurus SHO PP
Buzz360
Vehicle: 2013 ford taurus SHO
Post by Buzz360 » Tue Apr 17, 2018 8:01 pm
Does anyone have a list of all the codes and what not for the 2013 Ford Taurus SHO?
