2016 Ford F250 codes
Ladder104
Vehicle: Ford 2016 F-250 XLT 6.7 powerstroke diesel
Post by Ladder104 » Fri Dec 01, 2017 10:01 pm
Is there a spreadsheet with the codes for a f250? Not sure if there is a lot of stuff that can be changed but would like to change the tire size. Very new at all this but was able to get the DPF screen to work using FORscan :D
CombatDork
Vehicle: 2013 F150 FX4 3.5L EB - 2003 Explorer XLS 4.0L
Re: 2016 Ford F250 codes
Post by CombatDork » Sun Dec 17, 2017 7:44 pm
I was working on a 2015 F250 and found the tire size field is in BCM in 726-45-01 2nd field. (xxxx-____-xxxx).
However, the PCM and TCM both started throwing out codes for BCM error "value out of tolerance" stuff. This killed Advance Track as well. The 3rd field also changed when using the BCM factory tire size selection options. (xxxx-0A84-____). This may be a check value for the tire size. Something that the PCM/TCM may use for advance track though, I'm not sure. Both values I found started in "11xx".
CombatDork
Post by CombatDork » Sun Dec 17, 2017 9:12 pm
