Disable mykey
Thesavo
Vehicle: Escape 08 3.0
Re: Disable mykey
Post by Thesavo »
Still no luck disabling mykey. I just updated the to version 2.3.14,and updated my extended license.
I am attempting to add a third key now. It looks like my tradition “8-cut" style key needs to be programmed with a 12-minute inverval between key 1 and key 2 reads.
The dealer only provide us with two keys,not three..
And programming failed. Do I have to clear this mykey first?
capocvi
Vehicle: 2015 Ford Fusion SE 4Cyl 2.5L
Re: Disable mykey
Post by capocvi »
Can someone help me? I've been trying to use Forscan to disable Mykey altogether but i cant seem to connect. I have a '15 Fusion SE, and i bought this OBD tool https://www.amazon.com/gp/product/B01F0 ... nk20295-20
Its only USB so i tried connecting through the windows verison of forscan but its not working. Am i missing a step? All i did was unbox the tool, plug it right in, and tried to connect to forscan. Also when connected to the OBD port in the car, the tool seems to stay on a solid red light only. Any ideas?
Andyfocus
Re: Disable mykey
Post by Andyfocus »
capocvi wrote:
Tue Feb 05, 2019 6:31 pm
maybe install the drivers for the adaptor might help , plenty of links and help in the forum or a quick internet search.
Wbuffalo742
Vehicle: Lincoln, gas,3.7,2014
Re: Disable mykey
Post by Wbuffalo742 »
There's a new way to do this without having to download your body control module and it only takes about 5-10 minutes to do. Without having to use a computer. Without having 2 keys and without having the 2.1V software. I came up with this way of clearing the MyKey issue on my 2014 Lincoln MKZ. I only have one key to my car and it got set to a MyKey when I replaced my battery. How I'm uncertain. I only have the V1.5 firmware and I also kept having the issue with not being able to connect to Focccus/Forscan or any other app that might allow the MyKey reset. There is only one app that I found that helped allow me to get the MyKey bypassed but it did not make it permanent at first! I made a video to show and describe all the steps I took to get the MyKey cleared. If you all need any help with this, just let me know. Thanks!
https://www.youtube.com/watch?v=v0XrsYOXHB8&t=260s
Wbuffalo742
Re: Disable mykey
There is a different way to do this. I had to come up with a different way because I only had the v1.5 bluetooth and couldn't connect to Forscan or Focccus. I made a video that may help some of you. Here is the link https://youtu.be/v0XrsYOXHB8
sanchezadann
Vehicle: 2014 Ford F150 3.7L V6 Flexfuel
Re: Disable mykey
Post by sanchezadann »
Here is the link to the post I created viewtopic.php?f=16&t=10230
sanchezadann
Re: Disable mykey
benkej wrote:
Fri May 04, 2018 9:15 pm
travisnowak928 wrote:i have had success in disabling my key in my 2016 fusion titanium
With forscan?
I have 2016 mustang unfortunately I have only one key and mykey is enabled :( I looking for solution to disable mykey
I disabled mykey, its easy!!! go on my profile and look at my posts!!!
TimFor
Vehicle: Ford Focus, 1,8 TDCI, 85kW, 2007.
Re: Disable mykey
Post by TimFor »
What Wbuffalo742 wrote is using another software Fordsys Pro. I don't mind promoting some other product but I hate when it's done like this: check my Youtube..
What he does, after connecting, seems with keyless option only, is to:
- choose PCM (Power Control Module)
- press KOER (Key On Engine Running) to start engine in remote mode
- walk away with the key
- power the car off
- choose again menu Key on
- go to Settings and clear MyKey.
What anchezadann wrote is adding 2nd key and than using it to remove MyKey. Trouble is that cannot be done with all vehicles, such as Focus Mk3.
ktocho
Vehicle: ford escape 2.0 2013
Re: Disable mykey
Post by ktocho »
Help, I was using the FOCCCUS program to deactivate the Mykey and for some reason the car turned off and does not turn on anything, only the radio, so I can not re-enter the ECU because I can not put the ignition (it is a button start).
Airborne_Ape
Vehicle: F150, 3.5 Eco, 2017
Re: Disable mykey
Post by Airborne_Ape »
TimFor wrote:
Fri Aug 09, 2019 6:34 pm
This is the greatest thing I've read on this website all week.
