forescan can't write changes????
dickross
Vehicle: f150 SCREW 5.0, 2016
Post by dickross » Mon Jun 05, 2017 6:20 pm
Ithink I followed all the directions, but after I change a number and hit the write button, the number changes back to the original. I'm sure I missed something in the directions, but damned if I can figure out what. I've got an OBDLINK MX and a 2016 F150 SCREW.
Thankws,
Dick
dickross
Re: forescan can't write changes????
Post by dickross » Thu Jun 08, 2017 5:33 pm
I can't say a lot for the help from this forum, but i finally found the answer. I can write to most modules but not the IPC module (and maybe some others). This is a problem with the program and 2016 and 2017 pickups. An update to the program is in the works.
dickross
Post by dickross » Fri Jun 09, 2017 8:13 pm
Forscan sent me a test version of the program that took care of the problem.
Dick
mmmfloorpie
Vehicle: 2014 Ford Fusion 2.0 AWD
Post by mmmfloorpie » Sat Jun 16, 2018 8:42 pm
I'm having a similar issue now. Can write to door modules/BCM but will not let me do IPC.
Just says "service procedure interrupted."
Worked 3 years ago on my previous license. Had to get a new one today.
