2017 XLT F150 Trailer Brake Controller Activation
mlalberts
Vehicle: Ford F150 3.5 Ecoboost 2017
Post by mlalberts » Wed May 17, 2017 12:40 pm
I have a 2017 F150 XLT which didn't come with the trailer brake controller. I purchased the OEM controller and installed it a while back but haven't been able activate it in Forscan. I bought the ELM3727 blue tooth with the MSCan switch and was able to see the TRM Module with the As Built. It only gives me tow lines. 791-01-01-C000-005A and 791-02-01-009B. Does any one know if these are for the trailer brake controller?
jshanehood
Vehicle: F150 2.7 Ecoboost 2017
Re: 2017 XLT F150 Trailer Brake Controller Activation
Post by jshanehood » Wed May 17, 2017 8:24 pm
From the videos I've seen, the Trailer Brake Control Gain Settings must be enabled. This is found in the IPC module. I too, am attempting to activate the TBC on a 2017 F150. I just received the OBDLink MX today. I'll try either tonight or tomorrow and let you know how it turns out.
mlalberts
Post by mlalberts » Wed May 17, 2017 8:37 pm
Thanks, mine does not show an IPC module. All I see is the following modules:
APIM
DCDC
PAM
BdyCm
FCIM
TRM
I have the ELM327 with the HS/MS switch. Is yours an XLT?
jshanehood
Post by jshanehood » Wed May 17, 2017 10:25 pm
I couldn't wait! Mine is the XL, but that shouldn't make a difference. The IPC controls the climate control, brake controller and several other things too. One of the videos I watched was an XLT, but a 2015, not sure what Ford changed.
Mine showed two IPC modules, one was "as built" and the other was blank. I used the blank one and found "Trailer Brake Controller" and Trailer Brake Controller Gain Settings." I enabled both of them. Now the TBC works as it should.
Are you looking under the "Configuration and Programming" tab (looks like a microchip)? The IPC is not listed under the "info" tab. Also, you must use the "extended License" version of FORScan, if you're not already. I might make a short video, as the 2017's are slightly different from the 2015 videos I saw.
mlalberts
Post by mlalberts » Thu May 18, 2017 1:46 am
Yes, in the "Configuration and Programming" tab, mine does not show the IPC module. I have the extended license and HScan/MScan switch. Maybe I should buy the OBDLink MX instead of what I have.
Post by FORScan » Thu May 18, 2017 2:37 am
mlalberts wrote:Yes, in the "Configuration and Programming" tab, mine does not show the IPC module. I have the extended license and HScan/MScan switch. Maybe I should buy the OBDLink MX instead of what I have.
You need an adapter with MS-CAN support to access all of your modules (actually, majority of them are reachable via MS-CAN pins). If you have OBDLink MX BT or ELS27, it should work out of the box. Otherwise, you need to modify your adapter for MS-CAN as described, for example, here: http://forscan.org/forum/viewtopic.php?f=4&t=4
Here is a screenshort that illustrates typical configuration for 2017 trucks, red square shows the modules that are only reachable without MS-CAN.
As soon as MS-CAN support is added to the adapter, don't forget to remove vehicle profile in Vehicle->Profiles.
mlalberts
Post by mlalberts » Thu May 18, 2017 3:29 am
I do have the adapter. I have the ELM327 that has the switch wired just like the description above. It has the switch that changes if from MScan to HScan switched to the 3,6,11,14 pins. I am able to switch between the two in forscan to get the FCIM and TRM modules but I can't get any more. Am I still doing something wrong?
jshanehood
Post by jshanehood » Fri May 19, 2017 11:41 pm
I shot this video, maybe it will help.
https://youtu.be/O5gEhTa1btA
mlalberts
Post by mlalberts » Sat May 20, 2017 1:48 pm
Thanks jshanehood. That video was perfect. I found out my problem was the adapter. I purchased the OBDLink MX which came in last night and was able to see all the modules in the video. I activated the "Trailer Brake Controller" and "Trailer Brake Controller Gain Settings" and now they show up in the info screen.
lmcfarlin
Vehicle: Ford F-150 2.7 ecoboost 2017
Post by lmcfarlin » Sat Aug 05, 2017 12:47 am
Hi jshanehood, I too wanted to thank you for the video. I was able to turn on the factory trailer brake so I too get it to come up on my screen, but when I squeeze the trailer brake manually it doesn't show on the screen. The reason I ask is we use the f150 xl for work trucks and they come with trailer brake already installed and when I squeeze the one in the work truck it says something like (no trailer attached). Is there something else I need to do? Thank you Larry
