Pats Programing help
bwbjr
Vehicle: F150, V8, 2015
Post by bwbjr » Sun May 07, 2017 9:08 pm
Trying to program a dealer made key to pats and keeps failing, I am trying to add a key to the one I already have. Check key per site and says key is good. Where do I send the log files to have them looked at
Vehicle: Ford F150 5.4 Triton 2005 Expedition 5.4 2003
Re: Pats Programing help
Post by tractmec » Mon May 08, 2017 3:28 am
You will need to attach the contents of the log file folder in your C:\users\{your user account}\appdata\roaming\FORscan Folder to an email and send it to contact@forscan.org. It should contain a dump.bin file and a FORScan.log file.These instructions can be also found in the Forscan program by clicking on the wheel at the bottom of the list on the left hand side.
Hope this helps:
