Any way to do the following?
1. Add the turbo boost (in PSI) above the bar graph like you can with the engine and transmission temp?
2. Add oil pressure (in PSI) above the bar graph instead of just showing Low or High?
Thanks!
Loving this program so far!!
2016 F150 Gauges
- Vehicle: 2016 Ford F150 3.5 Ecoboost
2016 F150 Gauges
2016 F150 3.5 Ecoboost Lariat FX4
Re: 2016 F150 Gauges
I believe you can do the boost gauge. As for the oil pressure there is no way as it isn't a gauge but an idiot light that looks like a gauge due to the sensor being on or off and not a pressure sensor. Ford fooled you.
I have a 2017 EcoBoost and would like the turbo pressure also. Has anyone figured it out yet? I found the transmission and engine temp easily by using Google. This has alluded me thus far.
