do i need to use PATS to prgram key
jay ward
Vehicle: focus 1.6 ti-vct 115ps 2005
Post by jay ward » Thu Apr 20, 2017 11:55 pm
hi all,
I have a new key to program to my focus mk2 2005 (55 plate). In my hand book all it says is 'your vehicle is supplied with coded keys. replacement keys must be recoded together with your other keys.'
can this be done with the two original keys or do I need to use PATS setting?
also, do I need extended licence to check blank key is compatible?
clemo
Vehicle: Mk3 Mondeo 2.5 V6 ztec s
Re: do i need to use PATS to prgram key
Post by clemo » Fri Apr 21, 2017 5:37 pm
Try this see if this works. It is for the mondeo but the process will be exactly the same.
http://www.fordwiki.co.uk/index.php?tit ... rogramming
If this does not work you will need to go though pats programig.
Hope this helps.
jay ward
Post by jay ward » Fri Apr 21, 2017 11:04 pm
thanks clemo, will give it a go.
jay ward
Post by jay ward » Tue Apr 25, 2017 11:24 pm
hi
tried the key in key out etc. that does not work.
I take it I will need to obtain a licence to do this via the elm237.
I have 2 proper keys that I presume are original keys, one remote and one non remote that still has the plastic thing with numbers on.
jay ward
Post by jay ward » Tue Apr 25, 2017 11:58 pm
hi again,
have now obtained licence, wish me luck
jay ward
Post by jay ward » Wed Apr 26, 2017 11:04 pm
hi,
got the b1600 dtc code. key can not be programed.
can anyone tell me if there is a way to find out what type transponder chip is in original key.
thanks.
the joys of buying from online shops. it said it was compatible with my year and model. new key has 4d-63 chip
also when I unplugged elm237 and went out later the clock was 5 mins slow. any ideas or just coincidence?
thanks
jay ward
Post by jay ward » Fri Apr 28, 2017 10:51 pm
OMG,
am I thick or stupid?
is the plastic wedge thing that came with key for opening the key as I thought, or is it the chip?
if it is the chip I am thick and stupid!
clemo
Post by clemo » Tue May 02, 2017 9:31 am
If its the tiny little black peice with white writting on this will be the chip that goes into the key.
TimFor
Post by TimFor » Thu May 03, 2018 2:55 pm
jay ward wrote:hi,
Same question.
I got a chip that Forscan doesn't recognize. Seller wrote it's 4D-60. But I have Mk2 Focus that should be using 4D-63 according to http://www.transpondery.com/transponder ... talog.html. I'd like to verify this.
