Extended license won't activate
Pearldrummer7
Vehicle: 2017 F-150 5.0
Post by Pearldrummer7 » Thu Apr 13, 2017 2:40 pm
Hey guys--
I've searched this quite a bit. I'm running 2.3.8 on a Windows 10 64-bit machine. I generated a key (a few times, actually) and have tried using the built in Load function from ForScan, by opening it in regedit, and by manually copy/pasting the key into the registry location. I've restarted the application, restarted the computer, and tried reinstalling. Nothing will make this extended license activate. Any ideas?
fred08155
Re: Extended license won't activate
Post by fred08155 » Thu Apr 13, 2017 7:54 pm
Did you check your computer date settings to be correct?
Pearldrummer7
Post by Pearldrummer7 » Thu Apr 13, 2017 8:15 pm
I did. Auto set to EST. It's locked by GPO for me (corporate lappy)
Pearldrummer7
Post by Pearldrummer7 » Sat Apr 15, 2017 12:57 pm
So, I tried this on another computer (one which doesn't have bluetooth :( ) and it worked fine. I can't seem to figure out what's wrong with my laptop, but it really won't take this extended license. Is there another option? I need to activate my trailer brake controller by the end of the week so I can tow x-country with it. Really bummed I can't seem to use this other-wise good software. Is there a backdoor activation somewhere? Any hints would really be appreciated!
Vehicle: F150 5.4 Triton 2005 Expe5.4 2003 Fusion 3.0 2010
Post by tractmec » Sun Apr 16, 2017 4:56 am
Pearldrummer7 wrote:So, I tried this on another computer (one which doesn't have bluetooth :( ) and it worked fine. I can't seem to figure out what's wrong with my laptop, but it really won't take this extended license. Is there another option? I need to activate my trailer brake controller by the end of the week so I can tow x-country with it. Really bummed I can't seem to use this other-wise good software. Is there a backdoor activation somewhere? Any hints would really be appreciated!
Have you tried running Forscan as administrator and then loading the license key?
Pearldrummer7
Post by Pearldrummer7 » Mon Apr 17, 2017 11:51 am
I have tried running as admin. It does make the right registry changes, just doesn't work. I tried it on another computer (non-corporate) and it worked; worked on another computer with our corporate OS image loaded on it
sethjamto
Vehicle: 2016 Ford F150 3.5 Ecoboost
Post by sethjamto » Tue May 02, 2017 11:17 am
Did you ever find a resolution to this? I'm running in to the same problem on a Mac where I'm running Forescan on Windows Parallels.
2016 F150 3.5 Ecoboost Lariat FX4
procareshawn1
Vehicle: 2010 ford focus 2.0
Post by procareshawn1 » Tue May 02, 2017 5:50 pm
how do i get the extended license and how do i activate
KRIS-CAR
Vehicle: Ford C-max 1.6 TDCI 115km 2014
Post by KRIS-CAR » Tue May 02, 2017 9:17 pm
I have a technical question about FORScan, to one laptop I have 3 hard drives on each other I have other diagnostic programs, you will probably ask why this is so not to drive a few laptops, in my case I take one laptop disks and I have the ability to diagnose many cars, Back to topic today i had the need to program key in Tranzit Conect 2012r i connected to FORScan and when i tried programming jumped out the message that i do not have extended license, i tried to add the license key but without effect there is any chance to run extended license.
Sorry for my bad english
sethjamto
Post by sethjamto » Wed May 03, 2017 8:29 pm
sethjamto wrote:Did you ever find a resolution to this? I'm running in to the same problem on a Mac where I'm running Forescan on Windows Parallels.
I finally figured my problem out. Hopefully can too.
Here's mine:
http://forscan.org/forum/viewtopic.php? ... 057#p15057
