Cannot do PATS functions anymore
diceman01
Vehicle: AU Fairmont Wagon 1999
Post by diceman01 » Sun Mar 26, 2017 6:50 am
Hi there, I recently started using Forscan on my AU Falcon and tried the PATS function to erase and program keys. I also did a parameter reset and all worked well. My problem is now when I try to do these functions again I cant get past erasing stored keys. Everytime I try I get the message "The ignition key code erase was unsuccessful". I have tried different BEM'S and ECU's and still face the same problem. I am running Windows 7 in Parallels on a Mac and all other functions work. I'm trying to work out why this has stopped working and any help would be much appreciated.
martin123
Vehicle: transit connect 2003 1.8 tddi
Re: Cannot do PATS functions anymore
Post by martin123 » Mon Mar 27, 2017 8:38 pm
I had same problem today exactly.strange
diceman01
Post by diceman01 » Tue Mar 28, 2017 10:58 am
I have spoken to the Forscan admin and trying to work out the issue. From the logs I provided its a error in my vehicle so I am trying to find the cause.
diceman01
Post by diceman01 » Tue Apr 04, 2017 10:52 am
Well the error was me! Instead of turning ignition all the way to OFF I went to ACC. It all works perfect so thanks to the team working through the issue with me.
KRL-94
Vehicle: 2004 ford falcon 4L inline 6 cyl
Post by KRL-94 » Wed May 24, 2017 1:05 pm
Were you successful in programming a new ecu into your car??Ii work on a lot of AU Falcons and it would be much easier if i was able to do this instead of changing out the whole computer set.
