2005 Ford F150 ABS module VIN mismatch
lostking2008
Vehicle: Ford F150 4.2L, 2wd, 2005
Post by lostking2008 » Thu Dec 15, 2016 4:42 am
Hi There,
I am using Forscan 2.3.4 beta with extended license to write ABS As-built data to a 2005 Ford F150 (4.2L, 2wd) due to a DTC B2900 (ABS VIN mismatch). It goes well during the module configuration as seen in the log. But whenever I re-connect the truck via OBDlink SX cable to Forscan after the "successful service procedure", the DTC B2900 and ABS 760 block data from remain unchanged. Is there anything I am missing? Thanks for any input.
Ken
Forscan ABS configuration log
ctgcwiqc
Vehicle: FORD 6.0 1 TON DUALLY 2005
Re: 2005 Ford F150 ABS module VIN mismatch
Post by ctgcwiqc » Sun Jun 30, 2019 6:48 pm
I just installed forscan od ordered USB obd2 adapter to perform this very function. I sure hope it works. I am unable to d this with ford bundle and autoenginuity. Tech support with autoenginuity says it should work with new module, but not sure if will work with used abs module from another vehicle. Did you resolve this?
