Memory block/log comparison
j.osbourn80
Vehicle: f250, 7.3 turbo diesel, 2001
Post by j.osbourn80 » Sat Nov 12, 2016 12:38 am
So I've discovered how to edit tire size in my f250 via the ABS module using forscan canned options. Now I need to compare the saved FORSCAN log with the ASBUILT so I can locate the memory block associated with tires size so I can enter in my correct size and calibrate this speedo exactly finally. Can anyone please tell me how to view dump.bin contents.
